upgrade rev-cut for 4G91,92,93 ecu
I using 4g91 now.. i got some question here..
1)if i mod the ecu to stage 2, am i gonna need to change the cam or piston or conrod??
2)and how high can the rpm go? (4g91) i mean..
thx
1) for better response n high end power i recommended u to use 1.8 cam ( gti cams the best )
and stock bottom end no problem to handle up to 9k rpm.
2) for my spec 8800 rpm
Bump:
4g15 can aa? :hmmmm:
no problem bro it can be done.
for better info call/sms 017 6917136 :biggrin:
show me where is your workshop... i need more advice about this..
currently using 4g93t.. i want to know the life span to my engine...
hehehe
bro im using 4g91 carburator .. the fuel consumption is kinda bad ///
is it possible to convert it to fuel injection ...
wats ur best advice .. thanks .
Hi Bro, where ur location?? can pm me ur address? thanks
BRO, REV-CUT IZZIT OPEN electrotype? WIRA 4G15 CAN REV-CUT AR...?
Let say.. If I want to do the mod, does it effect any other thing on the ecu? example.. fuel map or ignition map?
yup bro , the map will transfer up , the concept like blanket , tutup kepala nampak kaki ,
for fuel map will lean at lower rpm . need to adjust fpr that all.
