- Joined
- Nov 16, 2005
- Messages
- 965
- Points
- 1,518
hmm: (my opnions n reading n research)
actually ar.. exhaust box end .. pipings n extractor all .. is change to better/bigger to "make/increase exhaust gas flows nicely n perfectly thru those pipings" instead of stock small pipings with small2 holes/tubes in diameter cyclinder.
ok lets make a comparison:
1) 1 bottle of water = u drink with normal straw (small straw like mamak)
2) 1 bottle of water = u drink with bigger straw (big straw like starbucks)
Q = which one feels better n faster n enjoy to suck water to ur mouth?
same goes to engine gasses:
stock pipings with cat converter till mid box till end and stock exhaust (of coz this stock factory got a lot of restriction
change extractor,remove cat converter,mid box till end bigger pipes.
basically change all those related to exhaust will make exhaust gas flows and go out better n smooth compared to stock pipes.
* FYI even tho its 2'5inch.. but inner its like 2'25 - 2.3inch
same goes to stock pipes .. 2inch but inner/inside is like 1'7inch 1'8inc
case like sharinling:
off coz i agreed that stock cars if tested with mod cars .. got different. in terms of original condition is good! and its always good. i do agreed
but .. even its stock .. can u guys tell me .. even its stock you still have restriction to it .. let say u got pickups.. very fast want .. but top end? can stock cars maintain 180-190-2xx above with throttle control? (like japs trying to catch up with europeans)
let say mod cars .. got bigger n potential of high speed top end .. it may lose to stock opponent at pickups or top end .. but when its potential of modifications get to its level. u will see big difference..
let say played with turbo:
off coz turbo will lead 1st. due to turbo spools,boost comes in .. but then you at behind trying to catch up (touge battle la example) .. but then in high speeds your car seems to be in front of turbo and turbo slows down .. why? turbo gots its own limit.
so basically its just a examples.. maybe im wrong or not enough info. but seems good 2 me.
for me. mod cars,get good hp n whp. then can drive daily,go here n there. it should be fine. no problem. but dont mod until u wanna drive also scared. for what.. hehehe
