Soundstream TRA960.4 - Top Range of Tarantula Series
ICE -In Car Entertainment
malcolm922
When sound quality and performance are a must, the Tarantula series amps are the most aggressive amplifier on the market today. These amplifiers feature SMD Technology along with a 3:1 power supply ratio that gives
the listener extreme amounts of headroom, speaker control and sonic accuracy. When only the best will do, Tarantula is your first choice.
COMMON FEATURES
• Variable hi pass, band pass, low pass fi lter
• Variable 18dB bass boost
• Double side glass epoxy circuit board
• PWM mosfet power supply
• Tri-guard amplifi er protection
• SMT cooling fan built in
• Tri-mode capable
• Line output
SPECIFICATIONS
No. OF CHANNELS: 4
OUTPUT(watts):
RMS @ 4 Ohms - 120x4
RMS @ 2 Ohms - 240x4
RMS Bridged @ 4 Ohms - 480 X 2
T.H.D: - < 0.02%
SIGNAL TO NOISE RATIO: - > 115dB
DAMPING FACTOR: - > 500
FREQUENCY RESPONSE: - 10 - 50K
INPUT SENSITIVITY (VOLTS): - 0.15 - 12.0
CROSSOVER SLOPE - 18dB
CROSSOVER FREQUENCY (Hz): - 50 - 5k
DIMENSIONS (INCHES): 10.75x2.25x25
Few free to call me n meet up to audit the amp as it still installed in my car at 0123990891
Used - 1.5 years
Selling at RM2.2k
http://ampguts.realmofexcursion.com/Soundstream_Tarantula_TRA960.4/inside1.jpg
http://ampguts.realmofexcursion.com/Soundstream_Tarantula_TRA960.4/inside2.jpg
The actual photo of the amp will show by tomorrow.
http://ampguts.realmofexcursion.com/Soundstream_Tarantula_TRA960.4/outside1.jpg
Bump!!
http://photo.ringo.com/264/264742483O201271605.jpg
http://photo.ringo.com/264/264742494O467762025.jpg
http://photo.ringo.com/264/264742496O052782105.jpg
Update ! & bump
