Speed Demon said:Measure the width and length of the engine and also your engine bay. It will be a tight fit but it most probably can go in.
Engine mountings and also driveshafts have to be modified. You also have to check the suspension and brake systems.
For driveshafts, you should custom make them. Cutting and welding the GTti driveshafts is NOT SAFE.
If you don't have RM5000 and above, don't do this conversion. Remember the engine you are installing in is also not new, so you might have to change/repair some things in it too.
thanks guruss....I agree with you Mr Speed Demon...cutting and welding the driveshaft is DEFINITELY not safe...
wonderinglah, Is the cost of conversion the same all over Malaya?..or would it be cheaper in Seremban...or Penang?
maybe I should upgrade my brakes first macam bawak kete flintstones pulak rasanya...
