Snow Performance Water Methanol Injection System.
RASHID
hello guys..
need advice n benifits on this..
my car is NA..
just tell me wat u think or have used this system..
thanks..
for an na, not much performance can be gained, especially if u r using std motor sir, extreme compression motor may need dis to help keep preignition at bay. fyi, u can gain a lot of hp jugek from fine tuning alone. weve seen a 40hp increment when a B16 was tuned properly by joshua thiran of millennium motorsports asia on the dyno dynamics sir
thanks man..
good info..
wat say u..
im drivin a myvi 1.3 auto wif exhaust n intake plus e-mange..
now 90hp..
how many can i get?
cincai kira la..
plus i willin to spend the money cause i plan to put on my future car too..
prelude H22A..
ive seen a 1300cc carb putting down approximately 80hp on the dyno dynamics, not even tuned tu.. i recon urs shud make more, a 100 on the dynamics? is dat 90hp tuned? on which dyno sir?
what about for kancil wif L502 turbo engine? standard out-from-the-factory spec is 8.7 compression ratio with 0.8~0.9 bar of boost
really like the idea of water injection idea. intended to use it as a means to further cool the post-turbo air... but really bothers me, does the snow performance kit really suitable for a tiny 660cc engine?
with the proper setting, u can increase the boost and tune it up more aggressively, which will then make more power sir. the function of this thing is, it keeps preignition at bayand allows for a more aggressive setting / tuning, which is where the real power comes from. the unit alone doesnt produce much, if any, increment.
a charged engine benefits more with d water injection kit compared to an na machine
yes bro..
90hp tuned..
i dunno wat u mean by which dyno but..
it was dyno tune at N1 racing..
yes for me..
if i can get around 10hp plus a little more torque..
will be very happy wif the results..
from my reserach this system..
all car can use..
small cc to big cc..
soo far no bad reports..
good product..
thanks guys..
Izzit true you can compensate for low octane fuel used in a high octane required car using water injection?
40hp is stock b16 or modded b16, with snow only or with other things together..??
40hp is on wheel..???
yes bro..
90hp tuned..
yes for me..
all car can use..
good product..
thanks guys..
so it was tuned on the dynojet den, 90hp isnt much on the tyres iam afraid.. 90 hp on the dynojet doesnt come close to a 90 hp on a dyno dynamics. a water / methanol injection can be used in all motors, no doubt sir
---------- Post added at 08:43 PM ---------- 6 hour anti-bump limit - Previous post was at 08:34 PM ----------
yes sir, just make sure u wont run out of juice if it has been tuned more aggressive when using a comparatively lower ron fuel. if u do run out of water / methanol, den drive carefully, dont simply tekan when dis happen, avoid pinging at all cost
---------- Post added at 08:46 PM ---------- 6 hour anti-bump limit - Previous post was at 08:43 PM ----------
the block is standard, but being a civic wit ha vtec inside, the owner cant resist to get a bigger zorst diameter. dat was all sir
owh2 pricey. what's the max boost the snow can enject at? any links for that item :biggrin:
then, need to use http://www.snowperformance.net/product.php?pk=13 la, but need stage 2 boost cooler... as RASHID pointed out, the cost is :bawling:
still cheaper than Aquamist, acceptable la... coz if turbo car, can increase up to 80hp... really worthy...
my wishlist got 1 only.... but seems like gonna wait for long time again.... strike toto jackpot rm47mil....
if increment up to 80hp, for rm 2500 really worth. coz just spent rm 5000+ just to get 30WHP increase :bawling: .
ya guys..
for turbo really 100% recommended la..
confirm increse minimum 40 hp..
40hp for 2.5k is consider a great deal..
is good for the engine life span too..
plus u save some fuel..
i really need to be savin shit..
cant wait to fix it..
