cheehong said:actually wht is the function of the rsm and safc?im still confuse with these....
any body pls tell me?heheh
daze said:only tried 170+km/h. just slightly above 170km/h at speedometer.. maybe 172km/h
believe still can go.. up to 175km/h or more.. but engine are roaring liao..like kena asthma..working very hard.. On my Satria SE.. ngam ngam 6 months. but mileage around 18k km liao.
Actually, rims are one issue, i believe... others.. i think because is a SOHC la.. not a rev-able engine. so can't expect much on top speed... after 150-160km/h it takes time to go faster liao...
Not like DOHC engine...
micwin1437 said:FYI
SAFC can be use for any fuel injected car
VAFC is for V-tec car
for more vafc info go to the link below
http://www.apexi-usa.com/product_electronics_detail.asp?id=201&pageNum=1
u guys can search the answer from WWW if u rajin enuf....:)
gavan said:wow, bro, i think you better check your fuel filter and also your air-filter....
dun lar say SOHC engine very chia lat like that...i also using SOHC engine leh.....:frown:
cyclonite said:You're wrong. Don't read the site literally. You know how SAFC works? It 'tricks' your ECU by manipulating sensor data to get your ECU to do what you want it to do. In the Wira SE or Satria SE the ECU is a Siemens brand model which does not have a MAF(mass airflow) sensor. This means that there's less sensor data for the SAFC to trick the ECU.
cyclonite said:Sure you can still install the SAFC but what do you want it to do? You can even install SAFC on a carb car and use it as an RSM :) coz SAFC has a rev meter function hehehe.
Similar threads | |
