safc 2 setting
nzamkh
Hello.....Bro,anybody know how to setting safc2 on my ride 4g93t...please help me.:driver:
bare in mind without proper air/fuel ratio monitoring using wideband sensor, u may damage ur engine...
u can just play around with safc but at ur own risk hehehe... gud luck...
or
call me 012-2800028 i can tune it for u with a minimum duit kopi...
if u mean the basic setting...
1. Sensor Type - Karmen
2. Cylinder 4, Throttle (Arrow up)
3. Throttle NE point usually LO- 30% HI- 50% (that is most common driving style I noticed la)
AFR cruise (steady throttle) 14.7-15.1
AFR part throttle pick up 13-13.5
AFR WOT 11.5-12 (Depending on boost as well)
On cruise AFR sometimes cannot set too lean because you suffer pick up power during closed to part throttle.
The above is the usual la... of course if your tuner have different ways.. and you feel that the car performed as you expected.. den good enough edi... cheers!
Remember AFR will depend on how efficient your fuel system is..never assume you have enough fuelling for higher boost outputs because you purchase some bad ass fuel regulator.. not until you stick a wideband sensor in your exhaust at the least.
wow...thanks ftzone...
really helped me owt...
really appreciate ur advice!
cheers bro!
