RX8 or RX7??
hotzwheels
Can anyone tell me which car is better??
Noticed that a lot of discussions on RX7, what about rx8??
turbo is the way to go....but I guess a Rotary NA can't be all that bad.... The LeMans Rotary was NA but quad rotor...
the debate was on RX8 club for ages... it's everywhere.....not just here. go search from the internet. :)
You're comparing a new and a old car, kinda the weird.....
IMO RX7:
- Insanely fast and easy to mod than RX8.
- still stylish after all these years.
- Good for couple.
IMO RX8:
- Better fuel economy
- Not as fast as RX7 but the speed is there
- Inherited some styling clue from RX7, that will make car looks good for next 15 years :_:
- good handling with 4 person seater.
Like what lennon said and the price tag: one is under 100K and one is ~200K.
If moolah is not an issue, turbocharged the RX8..... or get the GReddy version from Mutiara Motors in JB... fooo yoooh.
Either that get the RX7 and throw in the Veilside Fortune Model... double fooo yoooh...
Well that is my opinion anyway...
hehee... get the RX7 with Fortune bodykit is way way way better than the Greddy 8... hehehhee....
Hey guys,
Just saw the perfect machine today that has all the full specs...
thought I needed some reassurance.. hee hee....
I just fell in looove.... with this RX8 and paid for it today.. at least its not modified or anything, which allows me to throw in the extras!!!!
Now its just waiting for the process!!
Why does it always take soooo long.. when you just cant wait to get in on the road......
hi there.... sorry to bumped an old thread
i'm not an RE owner...but i do find the RX8 quite appealing....
may i know what's the most affordable unreg price tag of the RX8 available on market now?...i've checked out listings and saw prices ranging from 14Xk to 200k...that's sure a large price gap there...but y? can anyone enlighten me on the differences?
besides, maintenance....how does the maintenance of an RE differ from the normal 4 or 6 cylinder engine rides? will parts be a problem? will mod potential be a problem?
lastly...hows the fuel consumption like?..auto? manual?
thanks in advance to all RE gurus here...
It could probably be due to its spec. (ie. Type-S, Type-E) etc. Differences lies on the transmission type, engine differences (4 inlet ports & 6 inlet ports, etc), different wheel size and design (16 inch & 18 inch), disc rotor size, etc and also of course it's year of manuf. and versions. (Evolve - if it's ever available outside of UK, Sport Prestige Limited II, REAL Mazdaspeed, Shinka special edition, etc)
I've also come to known that the Type-S 6-speed manual comes with a rather light propeller shaft. So light that it actually 'feels' and looks like its made out of carbon fibre though I can't really confirm it's actual material used.
On a Type-S stick-shift, fuel comsumption is ok with a full-tank (around RM100+ worth of petrol) giving out 400km+, going easy with the throttle on a good day.
A nice and well balanced car I would say. Very nippy and neutral car to drive and tuck around corners. If you're looking for sheer, brutal out-right speed, the RX-8 may not be your type if you want to remain it in NA form.
Oh and there's one thing I'm real curious about. Does rotary engines run way much hotter than let's say, a turbo-charged 4 banger? i've seen oil-temp and water-temp readings as high as 90-100 degree's C after some short spirited drive. The car has stock radiator with an additional mazdaspeed oil cooler..
with twin oil coolers should not run that hot.. it's either their oil is bad quality or the oil cooler does not have appropriate duct....
heat is always a problem for rotary. that's why they all 1st thing need to install a water temp. oil temp is also important but not as badly needed as water temp.
4 bangers vs 2 rotors.. of course 2 rotor is hotter... always rotary is hot... unless you're saying like 500 to 600 horses of 4 bangers or 6 bangers they might be close to 2 rotors.
bear in mind... rotor = heat
thanks for such quick response....hmm looks like there's a lot diff. specs...
hmmm..thanks a lot fellow sifus.... ;)
Alchemis,
Thanks for the speedy reply. It's running on Motul Chrono 300V, with both the oil coolers sitting behind original air ductings..
Oh well :)
The driveshaft is made of carbon, very light indeed..... 350Z is having carbon driveshaft too...
Renesis engine is hotter than RX7 even with two oil cooler, becos of higher compression and the engine exhaust port position........ Plus the jammed-pack engine bay which trap lots of heat....... better ventilation will helps a loot...
Maintenance won't be much different from piston...... spark plugs are expensive, around RM450, RM650 for NGK racing type....... As for engine oil, better use Rotary oil and mineral oil only....... The reason is becos most engine oil will left deposit of carbon in engine...... As a result, carbon can wear out apex seals faster, jam the engine and apex seal springs...... you dont want this to happen....
Parts are available rather easily these days.......
Lennon,
The 'mineral oil' issue has been real cloudy for me for quite awhile and since you brought it up, I would like to take this opportunity to get a clearer view on why and how would a fully-synthetic oil from say, Motul would leave deposits of carbon in the engine itself.
I'm not an oil guy nor do I have a vast background in 'fluid-engineering' some say.. so pardon my ignorance if I do make/ raised any unsensible remarks or questions.
Let's use Motul fully-synthetic engine oils as a example. Being the fact that it has double-esther as one of the ingredients in the engine oil itself, I'm under the impression that esther-based engine oils are a very good cleaning detergent. So how would that cause carbon build-ups by the oil itself?
On a totally different note, where can I find RE engine oils and which grade would you see deem suitable to be used in a country like ours that has 365days of summer?
If there's been a discussion on the engine oil issue earlier, I apollogize for bringing this topic up again.
Thanks Lennon
wow that's a lot of facts...
hmm...parts available easily?...izzit really expensive? say compared to the evos or subarus....
also...how bout mod / aftermarket mod parts....?
hamsap said:
Lennon,
Thanks Lennon
Sorry to hijack your post
here is my experience....
10w40 is very suitable for the car for everyday drive.....I'n fact i am stuck to it now:regular_smile:
I've tried a few grades of engine oil.....15w50, 5w50
so far the lowest oil temp i get is with 10w40 average around 90C even during traffic jams.... my car has 2 oil coolers as well, one original mazda that came with the car and one HKS oil cooler...
just a note the lower the viscosity the lower the fuel comsuption...and get the engine more lively as it requires less force to run.... on the down side if the engine gets hot and your oil viscosity is too low, the oil will become too "light" and you don't get the engine pulling its optimum potential during higher rpms...so during extreme conditions for example track, higher viscosity is recomended. so far I have tried up to 15w50 on the track... works flawlessly
I have been using fully synthetic Motul 300v competition engine oil for 2 years and the car still feels just like new :_:
I have seen my friend's RX-7 13B rebuild and the only oil he was on is motul.... don't see any residue also :omg_smile: when the engine is taken apart
so u decide on which grade of oil u are going to, its more of personal preference and feel when u drive your car.
the type of oils to choose from mineral, semi syn or fully syn its more of what u believe in but make sure its suitable for the car( read owners manual)
me? i believe what i see :shades_smile:
just my my honest opinion( dont flame me yeah lennon tai kor...hahhaha)
the debate for oils still goes strong. There are many with differing views but most have come to realise Oil "Technology" has significantly improved. I use to preach the same idea of only running mineral back in the day (as that was what i picked up online) but nowadays i prefer running semi-synthetic as its clean and leaves not deposits. My most recent experience was during breakdown of engine (4k km) and i had only been running semi syn and premixing with 2T. The engine aside from its obvious problems (oil seals) was in perfect condition. There was hardly any deposits on the rotor or housings. It could be argued that the mileage was low but i had done 3 oil changes. Another reason i like semi-syn is because i see a slight reduction in oil temps when gunning the car.
Like Boony has said earlier, choose what you like depending on your application. Boony's advice on oil weights is in line with what many racers do. Try out what is in the market and stick with what you like best.
On a side note - what water and oil temps do rx8 owners see? Town Driving(Traffic), Highway and on Track? I appreciate the info.
There u go my data :)
Cruising
Ambience Temp 26C
speed 110-140km/hr
oil temp 70C
water temp 80C
Traffic Jam
Ambience Temp 31C
speed Damn Jams
Oil temp 90-92C
water 95-98C
Track (results taken after 3 laps around Sepang) *15w50 motul
Ambience Temp 29C
Speed High revs all the time
Oil temp below 100C *no time to see so just take the highest reading
Water below 100C
ok...so from the discussions above....so its pretty necessary for the RE be it RX8 or the earlier 7......to have two oil coolers.....?
anyway...still wondering...since some mentioned that parts available easily?...izzit really expensive? say compared to the evos or subarus....
and ohh...i've undertstand that the RE on the RX7 requires a routine rebuilt after every ~150k km...is that true?
does this applies to the RX8 as well??
