RPM not functioning well
Looking For
bullet838
Hi guys..
To all the VTEC husler, i just want ur opinion/advise on how to solve my problem. My RPM got problem whereby it was not functioning well.
Scenario 1: When I turn on my car engine, it will rev up to 2k and then goes back to 0.
Scenario 2: When my car engine turn on / while im driving the RPM was not functioning at all.
Scenario 3: When I turn on my aircond, then my RPM will effect. It will go up to 2-3k then it will go back to 0.
* Note: My VTEC still functioning even though the RPM was not functioning*
Pls help me to solve the problem as i really piss off with this problem.
VTEC rulz.!! Anyway thank you in advanced.
bullet838 said:
Hi guys..
1st...u post in the WRONG FORUM...
but ur problem is meter KONG...tat's all
Rpm
anyway sorry for the wrong post ..
I have tried twice intall meter and the problem still persist. Some people say the problem comes from my ECU or maybe it comes from wiring problem. Pls help.
try reset ecu since it is not the meter problem
if stil cannot..realy hv to check wiring oledi...
Rpm
Ok. I will try to reset my ECU then .. do u know where can i do that bro? .. any suggestion to any of the good shop one?
u mean reset ecu or wat?
reset ecu can do it urself...
take out the negative side batery terminal...leave it for 45minutes.....after 45min, u press ur brake pedal for few times and then conect back the batery terminal...then go n start ur car...see problem cure o not..
if stil not, hv to check wiring...wiring can check at Ukay Perdana,zoo negara there....if u r near there la..
if PJ area i cant help....
Write your reply...
