Rim Crack Inside...
ampang_boy
Rim Crack Inside...Need Help..!!!
elo bro...
do u hav any solution if my rim crack on the inside lips?
any speacialist or recommended shop?
izit ok if im still using it after repaired? coz its quite an expensive rim..huh..
try searching through The Marketplace for such services or ask your tyre shop for recommendations. crack repairs are quite common.
it involves welding the crack seam, if done properly, it should not fail under normal circumstances. just make sure there are no air leaks
But normally straight change new set of rims. By repairing it needs very great skills.
Try to ask for trade in and get a pair of new shoes. :)
crack rim if repaired properly by a very skill welder in a proper way should be as good.you cannot weld straight onto the crack,u have to grind a groove oyer the crack so that the weld can fill it all the way for a stronger weld.Have u seen some ori rims with original weld...yes ! so what is the prob.....
