relation between Plug n Plug cable
huakenny
LB Performance
Kota Kinabalu
If im using ngk iridium plug...but using original plug cable..izzit ok?
wat is d different with original plug cable n performance plug cable...
it will helps in where? pick up? fuel-saving?
ori plug cable of course can use ler.....
performace plug cable of course also got use ler.... helps pick up.. car feels smoother... fuel-saving dunno...
but have to tell u....if u put plug cable...it will interfere with the ICE...
so its ur call man...either ICE or performance
Well, its like this a spark plug's spark efficiency depends a lot on the cables.
example, if you have a good spark but the cables have high resistances do you think you can get better spark ?
Spark plug and cables work togehter as a team....Well simple, good plug cables like NGK, Ultra or Hotwires. They have lesser resistances in the cables which means that current flow is more smoother without much electrical resistance. A performance plugs is better then normal plugs cause the spark that it generates its better than normal plugs. So if you use performance plug with ori cables maybe the spark that produce by the plugs is not at it best efficiency....
theres a formula to calculate between voltage, current and resistance..
V=I*R
V-Voltage
I- Current (Amp)
R- Resistance
So if R is greater then V will be lesser.....A better spark provide beeter combustion and FC...A good set of cables wont affect your ICE system cause there will be no leaking of current that affect your ICE...
my opinion : for the plug and cable upgrade unless can gave us better pick up, smooth , esay to start at morning early and another important point is to minimize carbon remain at valve after compression.
guys...
bout tis aftermarket/performance plugs+plug cables,IMHO,if yr engine is STOCK or done minor mods,etc filter+exhaust.. its better to stick to the OEM items to save u a whole lot of problems+$$$ later...jus read www.magnecor.com for further info regarding tis so called "Performance" items...
