rojak mivec head is the best
datz why must change to 3 layer aluminium koyorad radiator lo..hahaha!!!, but heard from ppl 1.8 wit mivec head heavly mod always has overheating problem true???? are u using this type of mod!!!![]()
go for a well known gud setup that people normally do laa
RPW cams are good but quite expensive,JUN also damn expensive, i can get for u kelford for 4g93.. as for ecu same laa 4g93 ecu..can be tune with piggyback..dun simply port ur head..N/A engine diff from turbo..
R3 produced their own performance parts if i'm not mistaken,they got their extractor,cams,r3 ecu is basically the same as 93 ecu..the engine is the same..
as above wanting to know if it worthy fitting cams 272 on a r3 engine without mod block!!! so standard block wit p&p head control by afc neo!!!!! wit do u expert guys think!!!!:rolleyes:
4gna!!! thanks for the info bro!!! eeeemmmmmmm shall i do it or not!!!
go to R3 and ask them to install the R3 stage 3 high cam, they will tune your ecu for you so you won't have idling problem =)
....oh ok!!! where is that ah bro!!???....
R3 camshaft's lift and duration is higher than normal satria GTI
R3 Camshaft > SGTI & Putra > MMC 4G93(Normal 4G93 from japan halfcut)
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
i m looking for ganador side mirror for SW20,who got lubang to get it XD,come hlp me,replica 1 oso no problem
