Problems adjusting the 4-throttles !!!
Hello friends, sifu, master, datuk, kawan-kawan sekalian,
I just had my SVT ITB removed, cleaned up, adjusted those lock nuts at individual throttle (to synconize the 4-butterfly) according to BT service manual, etc. Everything go smoothly but now i have a poblem. Since i have adjusted those lock nuts position, i need to re-adjust the 4 idling bypass screws in order to have a balance air flow. This is because the current position of the idling bypass screw is set for previous setting (before i adj the individual throttle). If it is a BT ITB, i can easily remove the surge tank and plug in a carb balancer at each throttle to read the air flow. But now mine is SVT, i CANNOT run the engine without closing the surge tank. So, how to measure the airflow at each throttle?
Currently the distance of 4 bypass screws measure from the screws surface to the top end position are as follow:
throttle no. 1 = 3.6mm
throttle no. 2 = 3.6mm
throttle no. 3 = 3.7mm
throttle no. 4 = 3.5mm
Engine idling at 1000rpm min, slightly on the high side.
Please advice if you have came across any solution before, or you have an idea on it. Tks!
