Perdana cigarette port
dreamZz
Dear all sifu, I uninstall my HU today after that I noted my cigar port malfunction dy. Ther's only small light bulb is turn'g on while I switch on the car light. What wire and how many wire is suppose connecting to the port? Is it ground, direct and lamp wire? Plz advise. Tq!
normally 2 wire...12v and grounding...look for similar color male head socket that running lose among wires...join the connection back...
What is 12V wire?Direct wire? Can I find it by plug the tester at grounding and find the direct wire by seeing the lamp light on tester? Tq!
The cigar light should only come on when the headlamps are turned on. This means you will need to turn on your headlamps and trace this wire. It only gives 12V when the headlamps is turned on.
The HU also has a similar wire, where the HU will know if the headlamps are turned on, it will automatically dim. I'll recommend to start from here, as the cigar wire might be unplugged when the HU was removed.
Let's clarify the types of 12V wires in a car :
1) Direct 12V : That means this is connected directly to the +ve of the battery. Always ON.
Example : Wire to alarm
2) ACC 12V : This wire will only have 12V when the ignition key is to ACC & ON. This usually does not supply a lot of power, but just to trigger the electronic devices and relays.
Example : Usually trigger the radio to turn on
3) ON 12V : This wire will only have 12V when the ignition key is to ON
Example : Usually aircon blower & power window
4) Other 12V : Other 12V wires are mainly triggered by something.
Example 1 : When headlamps are turned on, all the other lights in the interior are also turned on.
Example 2 : When the horn is pressed, it will trigger a relay to power the horn (not all cars uses a relay for the horn)
New Posts
