Oil leak at Spark Plug
limch1
PJ
Got a new problem for my Elantra. Change to the Denso Iridium Spark Plug and noticed my original NGK spark plug got some oil leak.
It only happened at my 3rd spark plug where some oil leak are noticable surrounding the tip of the plug. Not sure if anyone having the same problem.
All this while I'm following the service schedule at Kah Bintang Jln 222. Hope it's not a very serious problem.
Check this out at http://www.magnecor.com/magnecor1/techbulletins/tech_mrbishi1.htm
so far i haven't encounter anything wrong with my previous plug change 2 months ago. My car covered 131000km todate. Changing from IK20 to IK22.
Oni got excessive carbon cos O2 reading not rite due to leaking extractor. Early morning start also no problem at all, never encounter anything abnormal yet except my fuel consumption.
recently also did ECU reset after bypass the coolant hose to TB.
HMS,
How's IK20 and IK22? Is there any different? How come they only change to IK16 for me? Maybe that's why I can't feel much different.
What about the coolant bypass? Does it help? Can you feel better performance when engine is hot or hot weather?
exactly the same problem to my coupe, also the 3rd plug. i just noticed that problem when i fixing a real disc brakes to my coupe when i back to hometown last two weeks. the mechanic feel that my exhaust flow is abnormal and also the engine is a bit shacking. and he asked me is that the fuel consumption very high compare to before and also lost of power... "it's what happened to my car this few months..." he straight away swap the plug cable to check, but the problem still persist. so he take a persure gauge to measure the internal valve presure, and really as what he said, the normal pressure for a normal valve presure will be at 150psi, if i not mistaken for the unit. but the 3rd valve presure only have about 80psi. it's cause by the internal valve leakage and need to re-fine the internal valve.and if the valve condition is very worst, then have to change it out. it cost about RM600 included the labour fee and all the gasket, not included the engine oil... so, good luck to ur car....
IK22 have much better respond than IK20. Can feel the difference a when u rev the engine time, the rpm climbs much faster and provide better power.
Reason behind, heat range 7 plugs absorb more heat away from the combustion chamber, thus its good to have cooler internals to reduce component fatique. Cooler also means less prone to misfire during high rpm, also provide stronger and more accurate sparks. Its also very good for high compresion engine, beta engine compression ratio is 10.1 if not mistaken, consider on the high side for NA non vtec non mivec.
Too cold is a problem too, spark plugs needs to heat up to about 500 degree to achieve self cleaning of excess carbons. thats y too cold will cos the engine to stall or irregular idling when these carbons cover up the plugs tip. Also will be harmful to the catalytic and o2 as well as ur engine oil getting dirty faster. But what I am trying to find out now is the advance technology of OBD-II ECU, will it know how to compensate the fuel when the o2 detects the changes, cos the ecu are suppose to maintain AF ratio.
the by pass really helps, power really comes, worth the trouble to do it. But i wonder y they need to direct engine coolant to the TB in out hot weather country ??? Even now i am thinking how to reduce the heat of the intake manifold, maybe i want to drill a hole and take some temperature measurement of the air inside the manifold so i can design a thing to cool it down to around 20 degree celsius (active cooling).
cws, is it possible cause by the mod that you done ?
wondering u mean ur exhaust flow abnormal, is it u mean the gas come out uneven pressure?
