need help!!
Leonhart
Hi all..merry christmas...great forum you guys have here!
I need some help...I drive a 5AT Altezza RS200 Z edition. Just now when i was at the car park my gear cannot shift from P to R. I could only shift gears if I hold on to the shift lock button located on the right on the gear box.
Anyone knows how to disable this as it is very troublesome? Many thanks!!
have u tried pressing the brake pedal b4 shifting from P to any gears?
if u have, then some other problem. go to trial or vision to check
tried that and it doesnt work....thanks anyway Green...I think i will bring it to the place i bought it 1st to check out and if it doesnt work i will bring it to either trial or vision.
many thanks again!!
lol
last i have the same problem with my dad's CLK. same problem and turn out to be a shifting pump fault. dunno if altezza is running on pump too or not.
You need to check your brake light switch connected to the brake pedal.. if the brake light switch malfunction, the CPU wont send the signal to release the mechanical lock at P position..
Normally when the brake pedal switch doest work, your brake light wont lite up.. check this first.
I had same prob before with toyota Wish.. I sprayed WD40 at the pedal switch, then it works as normal.
Write your reply...
