the sound i been searching long long time ago, after done few things also no use....still will da da da if u go through bumpy road
anyway this is the step and hope u can help me out on the sound also
- pull right side den left side of the glove box until the whole thing fall.
- u should see a white or blue, those pulling type of steel cable on the right part that connect to the air cond filter (the one u choose outside air or circulation), push right to take it off
- go to lower part of ur steering, see a white or blue, same type as above, which this one got to do with your air blow position one, pull right to get it off also.
- take out the cigarate ash holder, and the start pulling the lower bracket 1st, this part all clip, can pull without unskrew any thing if u have done the upper part, but u will be limited by the wires attach to the air cond controller.
- the wires socket is the hardest part, as u r limited by the space u can move, try ur best here with two sockets and a white clip of one of the socket. u r almost there if u can get this done.
- after throw the air cond controller aside, use number 10 box spana to open two skrew that on top of two steel bracket, dun have to take out the on the middle.
- start pull the upper bracket after the two skrews, start from the lower part, all clips, pull as u like but do watch out ur HU wire after all.
Here start ur mission. weird sound search!
Good luck!
