Anyone here use this product?
Any improvement HP & torque?
how to install ekkk..price..he he he
It will give you a very powerful spark,will increase response,power and fuel economy.But dont expect more than 6hp increase if your engine is stock n/a.Turbo or supercharged engine under high boost will see higher gains.
using this:
on a BT. Feels livelier / little bit more responsive; that's all. No noticeable difference in fuel consumption in my case.
sifu...nearest 6hp is d way too large amount for NA engine..tat is wat kaki vtec told me...heheheheh
Install at your ignition system la...bagi api lagi power,normal ignition voltage dekat coil 12V~14V je,pakai CDI voltage sampai 400V~500V...api kat plug pun meriah,hehe
Guys I also came across this on mudah yesterday and got curious. Can I ask, how to install this? It replaces you original ignition coil or just ad on to it? And, if use this, are there any bad effects on the cables, plugs etc since it gives powerful spark? Can the stock cables/plugs take this?
ha ha ha
nanti aku aku amik ..minum2 lagi..ha ha ha
