michiba weather vision 3000k
saga_se
good morning guys!
Has anyone used michiba weather vision 3000k bulbs on their car? I just wanna know how bright is it compared to hella or osram. Basically I'm looking for something bright and good for wet weather. Right now I'm back to using stock bulbs after uninstalling my HID set.
Michiba bulb not long lasting oh. Last time I thinking to use michiba bulb, but most of member told me not to do so. If you wan better and bright, buy PIAA brand, Gold Type. Very nice that bulb. But the bulb very expensive oh.. Blackpc. =P
At the moment i'm using GE Megalight. I was thinking maybe the 3300k Michiba can perform better in the rain.
GE is better ma.. That Michiba I not sure can perform or not. My HELLA can perform well in raining day.Or you wanna get those rally yellow bulb? can shot tru fog and rain. Actually I also wanna get those bulb can shot tru fog and rain, but the michiba just like normal HELLA and GE..
ahh.. thanks for the input my friend. I guess I'll stick to GE for now.
Michiba halogne i also not really recommend ... nothing much to impress me ..
no ar..i used H4 michiba white light 4350k...for 1 year plus liou....still ok..still bright..but i used relay la....not all michiba tht bad....certain range only...
add relay sure more bright ..usually over 4000k after add relay is bright one ..but 3000k ar ..hehe ... you can try la ..
been using GE Megalight for few days now. I'm very impressed with the range of the beam it generates. I rarely have to use the high beam on the roads I usually do.
Not only GE. Last time I used HELLA 55/60w also have same problem. I can't that the range of the beam. Then I change to 90/100w. The range of beam now is longer compare with 55/60w. But use this headlamp, scare need to change headlamp every 1-2 years. Cause with our headlamp quality, it will turn yellow fast.
