4G15 only la. I kinda regret actually. Doesn't really seem to go well with the engine. I think I needed something slightly taller, maybe from the GTI. Oh well, next time when money falls from the sky I'll do that.
err...sarcasm?
dont know about you, but most 'normal' people doesn't know what OD OFF button really do...
Some myth..
1) My car no good cause no got OD OFF button...only got 1 ,2 ,3 and D..:rolleyes:
2) Dont drive with OD OFF up Genting..it destroy you gearbox...:rolleyes:
3) OD OFF just like sport mode...it holds longer in gear...
4) Some people failed to mention the OFF. Just overdrive, means POWER!!
I also manually use the Auto..heel n toe downshift...release throtttle upshift..
hold brake with left foot to launch..
much2 faster...also sounds like manual gearbox..![]()
The pickup is definately better from start/stop situation. But in order to get best acceleration you have to switch the gear all the way to D1 1st and step on the gas & brake to rev up & pedal to the metal then switch to D2 D3 D4 if you have them.
Downside is autogear not meanth for heavy usage. You will suffer gear problems earlier & possible gear oil leak from the seals faster.
If you really want to shift gear should just use a Manual gear.
interesting! Ok. But from what I know there's no easily repairable component in the GB? Most cases it requires the whole GB to be overhauled. I dunno la, not on auto anymore so don't caaaaaaaaaaaaaaarrrrrrrrreeeeeeee..
Manual FTW!
think the fella is overwhelmed wit the achievment that he might need sumtime to recover & rejoin us back
Rarely drive auto car. But for me, the only reason to manually drop the auto GB is before entering fast corner n downhill. Even if I want to sprint at traffic light, I'll just using D, floor the pedal and let the ecu shift up. Ecu will do it at best rpm point. Some driver will start from L or 1, and shift up manually and think they'll go faster. Hahhaa... they may shift under-rev or over-rev. Even if the change it at perfect point, it still a two step job. 1st, driver change the gear level, 2nd, ecu detect it and start change the gear.
TCU la.
Renesis And if I had the option of swapping to manual on my current car, I would consider it when budget permits. But this car doesn't have a manual variant
TCU la.
Some latest models have the TCU in built together with the ECU, right?
So conclusion to shift A/T cars like manual doesn't help?
