the practice is to change the lower arm bushing set which consist of 2 pcs.
but due to the car has been runninng more than 10 years, for sure the arm might having a defect. ball joint loose or worn out, bend arm (car lowered down + harder spring and speeding at KL area..hahaha)
ball joint is fix.can't replace. its a press unit. come together with arm.
somemore, the SGP bushing will cost you RM140 per side. and extra rm40 for press out/press in and rm30 for assembly. total = rm210.
unless you wanna change to rigid-firm polyurethane bushing. its will give a firm handling.
try get it from Aussie website or ssgti.
i do have the quote b4 around usd200 the whole set front, rear and sway bar.
your ride will be less bodyroll.
SGP bush only oledi cost RM140. Tat mean lower arm for sure cost more than RM200 la!!! Anybody using polyurethane bushing. Superpro hav for our car. D hole set front and rear bushing cost RM14++.00. But i heard its too hard n not reliable. Only good for racing use. Is it???? Need advise from anyone who used it b4. The orange color bush is wat material??? Can it custom made here????
PU bushing is of course firm to reduce bodyroll and its not comfort.
PU can be colour, blue,black etc. depends on manufacturer.
rm1400?? err..ssgti quote me only usd200 but they have no stock.
they said"it was long time ago during 1995"..hehehe
ahman shop at tmn sri gombak. please call him to get there.
his shop is beside small bookshop and misc.
ah man= 0196661818
or can go direct to Seng Hui, suzuki authorized dealer at Sentul. in front of bandar baru sentul junction light. he also quote the same price.
BUT other parts is all SGP and its expensive a bit.
ulrta racing?? they specialist built the hollow bar so call stabilizer.
other product, they bought from HK, taiwan, china stuff and put their sticker in.
for performance parts, try get outside, Aussie, US, NZ etc..
Can anyone source me or know where to get this thing pls let me know ... My aircond condensor leaking due to faulty when i took out turbo than suddenly hit the aircond condensor plate ....then bocor lah ... try to...
Was wondering what is the best handling setup for turbo cars. Thought of adjustables but quite confused of which one to choose. Hope you guys could help. Thanks in advance
