leaking all around engine..
shahaff_07
to all sifu here,juz to ask u guys,why my engine is leaking wit oil,it all around a engine n my extractor manifold..its bout my gasket?and my car so dificult to start..its bout starter??help me...:nurse:
Re: licking al around engine..
You mean LEAKING engine oil?
Yeah, your gasket could be leaking.... or maybe your rocker cover is not screwed down properly. But, check the oil refill cap first :biggrin:
y he licking all around his engine lar. . . so dirty . . .
check d "licking" from d top (rocker cover, head, sump etc). go from d top till d bottom. frm my exp, if d oil leaks to ur extractor, usually d top part of ur engine (rocker cover gasket / head gasket / camshaft pulley o-ring worn oredi). dun forget 2 check at ur gearbox 2. usually d flywheel oil seal pecah after some time. make sure 2 check what kind of oil tht is leaking (engine oil ker gb oil ker).
car difficult 2 start eh. hmm, starter / battery / fuel supply / carb or fuel inj dirty. so many possibilities aa bro. if d cranking sounds rough or funny or weak, it might b ur starter motor
