SR20ve NEO vvl with 6speed gearbox year 2002......
:proud:
Displacement, cc 1998
Engine model SR20VE (NEO VVL)
Max.power (Net), kw(PS)/rpm 204 ps (150.04 kw) / 7200 rpm
Max.torque(Net), N*m(kg*m)/rpm 21.0 kg*m (205.94 N*m) / 5200 rpm
Power density 6.47
Engine type Water cooling serial 4 cylinder DOHC
Engine information NEO Di
Fuel system NISSAN EGI (ECCS) (electronic gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 11
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.7
SR20VE with Hyper CVT-M6 (6 fast manual mode attaching non-stage transmission)year 1998
Engine model SR20VE
Max.power (Net), kw(PS)/rpm 190 ps (139.75 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.0 kg*m (196.13 N*m) / 6000 rpm
Power density 6.79
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information NEOVVL
Turbocharger No
LEV system (Low emission vehicle) No
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.9
---------- Post added at 05:07 PM ---------- 6 hour anti-bump limit - Previous post was at 04:47 PM ----------
How bout Nissan Pulsar Serie engine...SR16VE 5 speed manual can play2 with vtec and mivec
Displacement, cc 1596
Engine model SR16VE
Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 7800 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.5 kg*m (161.81 N*m) / 7200 rpm
Power density 6.4
Turbocharger No
Bore, mm 86
Stroke, mm 68.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.1
