Latio to change with new engine.
ijau
Hi all,
Just thinking to convert my Latio engine.
Do anybody know what is the best engine to fix in?
i'm searching for light turbo's or superchagerd engined to fix in.
please shared with me if anybody have any experienced.
thanks.:driver:
i think 4E-FTE should fit.. it's 1.3L turbocharged
but it need lots of modification
:biggrin:
hi all,
thanks for the suggestion,but i really need to know the mounting need to be adjust or it just can fix it smoothly.
i'm trying to get much info to make this happen. seem the SR20 is so much person talking to perform inside Nissan.
i just wonder can it fix with Latio mybe with new chassis.
need expert here.
rebiuld the engine with forged parts. +++ bolt on turbo. :love:
this is more feasible..
all u need is a forged stroker kit, a custom turbo & piping.. and u'll fly
price i think more or less buying a halfcut n custom fit it into ur car..
plus lesser headache :biggrin:
Gudluck :burnout:
ermmm..nice input here.running with stock engine MR16 was too lack power or my engine starting giving problem.:trytofly:
need to find out the cost for rebuild this engine. seen at s'pore this type of car running with supercharged engine,but dunno what type of it....
yeah..now i'm start to think the best type engine to be...dunno what type it is.huhu.:banghead:
SR20ve NEO vvl with 6speed gearbox year 2002...... :adore: :proud:
Displacement, cc 1998
Engine model SR20VE (NEO VVL)
Max.power (Net), kw(PS)/rpm 204 ps (150.04 kw) / 7200 rpm
Max.torque(Net), N*m(kg*m)/rpm 21.0 kg*m (205.94 N*m) / 5200 rpm
Power density 6.47
Engine type Water cooling serial 4 cylinder DOHC
Engine information NEO Di
Fuel system NISSAN EGI (ECCS) (electronic gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 11
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.7
SR20VE with Hyper CVT-M6 (6 fast manual mode attaching non-stage transmission)year 1998
Engine model SR20VE
Max.power (Net), kw(PS)/rpm 190 ps (139.75 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.0 kg*m (196.13 N*m) / 6000 rpm
Power density 6.79
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information NEOVVL
Turbocharger No
LEV system (Low emission vehicle) No
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.9
---------- Post added at 05:07 PM ---------- 6 hour anti-bump limit - Previous post was at 04:47 PM ----------
How bout Nissan Pulsar Serie engine...SR16VE 5 speed manual can play2 with vtec and mivec :biggrin:
Displacement, cc 1596
Engine model SR16VE
Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 7800 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.5 kg*m (161.81 N*m) / 7200 rpm
Power density 6.4
Turbocharger No
Bore, mm 86
Stroke, mm 68.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.1
Write your reply...
