kenari cross drilled disc rotors
l2s_turbo
1,068
154
3,163
I suggest directly use honda's brake like what bro mADmAN said.. it should last you for a long time as the brake is bigger and you'll have less stress apply when you keep on braking.. my fren installed in his kelisa before... the result is tremendous.. :biggrin:
Wilson13B
296
30
528
So Myvi Caliper will plug and play into Kenari without needing to do any modification ?
Where had selling the IMP or any other performance cross drilled rotors for Kenari , i try to find on google but no luck .... i'm in KL/Cheras Area =)
Jan 17, 2014
Kota Kinabalu
bro if i wan to change my rear brake to disk wat do i need to buy.. + if i buy the myvi brake set replace it with my stock kenari can i use the stock front brake put it in the rear..
The Marketplace Top Posts
Does anyone knows how to remove this frame? Need to DIY change Kelisa HU.
Thanks.
