Just wanna ask..
lolz.. know it's better than stock.. nvm will give it time.. now if take sharp cornering, can feel the rear drift a lil.. not to bad, induce a sharper cornering..
tyres, i changed them 3 to 5 months ago.. maybe it's the broadness... hopefully soon it would be 16" with 195 or 205.. start saving again.. ;)
yest, on e way to Bangsar, i went thru some yellow strips at around 70 to 90km and it didn't felt that good.. (those yellow strips are those placed before a bump)..
hmmm
maybe it's driving style? were you braking into the corner?
try to do all of your braking in a straight line and take the corner without brakes (and without power) and only power out after/at apex.
because that's what it sounds like lo..
ah? wokie
we'll try to fix that when you come in the next time.
yeah, that's wut i did, usually before attacking the corner, just tap e brakes a lil and turn without accelerating, just let it be neutral and if not fun enough, apply accelerator then hit the straights, all the way full throttle..
the cornering is good no comments on it. except during road joints on the highway and uneven road joints on normal roads and the bumps..
will drop by sometime next week, hope u can get it done within a day cos life sucks without transport..
ah...
wokie let's see what's the issue and hopefully we can fix it ASAP :)
fixed.. done within 3 hours, yesterday, was the first to come in... am pretty happy with it although bit of body roll..
time for thicker arbs, strut bars, etc etc
stanley~~ i need to make my ride softer, my passengers told me they needed neck braces after sitting in my ride :P weaklings...
lolz, indeed, saw the strut braces from ultra racing, hope they can come up with something for the 206 since i will just b leaving the suspension as it is..
ah
could be the air being pumped out/sucked-in inside the body.
designed to do so.
this is the air that's pumped in and out by the action of the barrel moving up and down the body.
and the air escapes thru a hole size 3mm in diameter.. so hence the 'hissing' sound.
just curious, wut do u mean by bottoming out in terms of suspension? still notice some point in time when i go over small lil humps, my whole dash would rattle.. n besides that, was in Sentul area yesterday.. OMG.. the road was uneven and i got no choice but to drive really slowly.. :ph34r:
