JBL Audio Pacakge for sell
ICE -In Car Entertainment
Re: Automotive Genesis Promotion(until stock finish)
bring me up..........
Re: Automotive Genesis Stock Clearance
Re: Automotive Genesis october promotion(very highend amp)
Re: Automotive Genesis Stock Clearance!!!
bring me up
clear stocks
bring me up
2 channel amplifier RM 550
what model is this?
let me check first...
bring me up
clear stock.........
bump......
Re: [autogenesis] eclipse authorise dealer. Subwoofer 12" super price
Bump..........................!!!!!
Re: [Hi1983] NEW JBL 2008! PACKAGE [AMP+SUB+COMP ETC]CHECK it UP
pm reply .. BUmp,
call/sms me for fast reply thanks
012-3870968 felix / 016-2119926 jenson
Re: [AUTOGEN Hi1983] EClIPSE 4200 12" SUBWOOFER. HARI RAYA promotion
pm reply .. BUmp,
Re: [HI1983] JBL PACKAGE, component + 4ch amp + sub etc
pm reply .. BUmp,
sms me........
[wts] Brand New Power Amplifiers FOR SALE
All items sold here comes with warranty.
1.MA AUDIO MA-60.4iX 110W RMS x 4 Channel Amplifier RM590
Model: MA-60.4iX
110W RMS x 4 @ 4 Ohm
220W RMS x 4 @ 2 Ohm
Max Power: 1800W PMPO
Full MOFSET power supply
PWM Circuitry
4 Gauge Power / Ground Connections
Full Selectable Crossover : High/Flat/Low
4/2 ohm stable stereo
Variable Low Pass Filter : 50-250Hz
Variable High Pass Filter: 120-3KHz
Variable 12dB Bass Boost at 40Hz
Frequency response: 10Hz- 30KHz+/-3dB
Power Bandwidth 18Hz-22KHz
S/N Ration : 98dB
T.H.D: 0.02%
Chorme Plated RCA Jack and Terminals
MA audio badge on amplifier
Line out
http://s.lowyat.net/uploads//attach-90/post-83190-1197801511_thumb.jpg
2.MA AUDIO MA-3001D 600W RMS Class-D Monoblock Amplifier RM720
300W RMS @ 4 Ohm
600W RMS @ 2 Ohm
Max Power: 1400W PMPO
PWM MOFSET switching power supply
Adaptive Class D technology
High powered transformer
High powered stacked inductor
Pure N-channel design
Doubles power into 2 ohms
Real time computerized protection circuit
Color-coded wire harness for speaker-level input installation
Acousticallly seamless turn-on/turn off (i.e. noise)
Low-pass crossover, 115Hz, 24dB/ octave low pass
Switchable bass boost @ 0,6or 12dB centered at 50Hz
Low level inputs
Adjustable input sensitivity
Chrome plated RCA jack and terminals
http://s.lowyat.net/uploads//attach-90/post-83190-1197801555_thumb.jpg
3.WECONIC VX-604 110W RMS x 4 Channel Mofset Amplifier RM480
110W RMS x 4 @ 4 Ohm Stable
2200W RMS x 4 @ 2 Ohm Stable
PWM Circuitry
S/N Ration : 98dB
T.H.D:> 0.02%
Embossed logo design
Line out
http://s.lowyat.net/uploads//attach-90/post-83190-1197801589_thumb.jpg
4.HERTS Acoustic Monoblock Car Amplifier (with Digital Volt Gauge Display) 600
(Brand new in box + 1 Year Warranty)
Full MOSFET Power Supply
1 Ohm Stable Stereo
Low Pass Filter (50Hz - 500Hz)
Phase Control (0� - 180�)
Frequency Response: 10Hz - 30KHz
S/N Ratio > 90dB
T.H.D.: 0.05%
Selectable Bass Boost (6dB, 0dB, 12dB)
Subsonic Filter
Gain Control
Chrome plated RCA connectors and Screw Terminals
Power & Protection LED Indicator
Digital Blue LED Volt Meter
http://s.lowyat.net/uploads//attach-90/post-83190-1197801616_thumb.jpg
5.Kenwood KAC-6401 1000watts RM580
[Brand New in Box with 1 Year Warranty]
PRODUCT DESCRIPTION:
-1000 Watts max power
-800 Watts (4 ohms) RMS
-30 Watts x 4 (4 ohms) RMS
-Frequency response 5Hz to 50kHz
-Built in low pass filter (80Hz)
-Built in high pass filter (150Hz)
-Speaker level input
-Gold plated input & output terminals
http://s.lowyat.net/uploads//attach-90/post-83190-1200129140_thumb.jpg
6.PYLE AUDIO PE-354 75W RMS x 4 Channel Mofset Amplifier RM390
Specification:
75W RMS x 4 Channel Amplifier @ 4 Ohm
Full MOSFET Power supply
2 ohm stable stereo
Variable Low Pass : 50Hz-500Hz
High Pass : 50Hz-500Hz
Frequency Respone : 10Hz to 30KHz +/-3dB
S/N Ratio : 98dB
T.H.D:> 0.02%
Tri-Gauge Protection Circuit
4 Gauge Power/Ground Connections
Thermal Overload Protection
Chrome plated RCA Connectors and Screw Terminals
http://s.lowyat.net/uploads//attach-90/post-83190-1203130276.jpg
7.V12 MRV 1000watts 4/3/2 Brigdeable Mosfet Amplifier selling RM240
V12 MRV 1000watts 4/3/2 Channel Bridgeable Amplifier
(BRAND NEW + 1 YEAR WARRANTY)
Product Specification:
AMPLIFIER MRV-F705
Average Power Output/CH into 4 Ohms, 4 Channels Driven @10Hz~40kHz, 0.5% THD 85W X 4 or 170W X 2
@1kHz, 10% THD 250W X 4 or 500W X 2
Low Pass Filter (VARIABLE) 40Hz ~ 150kHz
High Pass Filter (VARIABLE) 80Hz ~ 1.2kHz
Output of Bridged (BTL) Operation into 4 Ohms @ 1kHz, 1% THD 1000Watts
Frequency Response (-1dB) 10Hz ~ 40kHz
Signal to Noise Ratio ("A" WTD) >100dB
Input Sensitivity 100mV ~3V
Input Impedance 22k Ohms
Operation Voltage (Negative Ground) DC 12V
Speaker Impedance @ Stereo Driven 4 Ohms
Fuse Rating 40A X 1
Dimension (WxHxD)mm 260X58X320
http://s.lowyat.net/uploads//attach-90/post-83190-1203130289.jpg
http://s.lowyat.net/uploads//attach-90/post-83190-1203130302.jpg
8.Revenge Digital RV-888 2 Ch 2400W Amplifier RM320
Power output 4Ω(watts) 75W X 2 CH
220W X 1 CH bridged channel pair
THD ≤0.1%
Frequency response ( ±1 db) 10Hz~25KHz
Signal to noise ratio >
Sensitivity 0.15~8V
Recommended fuse type 30A X 1
Dimensions 308mm X 215mm X 50mm
http://s.lowyat.net/uploads//attach-90/post-83190-1222866271_thumb.jpg
9. Vibe Sound VB-268 2 Channel 1200W Amplifier RM290
MODEL:KAC829/V6
2CH POWER AMPLIFIER
4 OHM:2x40W
2 OHM:2x60W
BRIDGE (BTL): 1x80W
MAX IN POWER 400W
RESPONSE 20Hz ~20KHz
Dimension: L=202mm W=252mm H=57mm
N.w.:2.3Kg
The centre panel of the amplifier lights up when amplifier is power up!
http://s.lowyat.net/uploads//attach-90/post-83190-1222866359_thumb.jpg
10.BRAND NEW XETEC VECTOR V150.2 75W RMS x 2 Channel Amplifier RM940
Aluminium heatsink
2x75W Rms
4 Ohms stable
Bridged mode : 1x180W 2 ohms stable
HPAA technology
Highpass, lowpass filters with bypass function
Input sensitivity 250 mV - 4V
Full protection(DC; Overheat, Shortcircuit, Overload)
Gold plated input terminals
Recommended for RS AUDIO C-8, C-10 or C-12 SVC Subwoofer
Made In Germany
http://s.lowyat.net/uploads//attach-90/post-83190-1197857772_thumb.jpg
11.SOUNDSTREAM LOS 2CH MOSFET Amplifier RM650
FEATURES
Brand : SOUNDSTREAM
Model : LW2.240
. Power Output : 60watt RMS x 2
240watt RMS x 1
. 4-way crossover system:HP,LP,BP & Full
. Full MOSFET power supply
. PWM circuitry
. Tri-mode capable
. Frequency Response : 20-20Khz
. 18dB bass boost
. High/low level input with floating ground
. line input
. Blue illumination around on Spider's logo
. Dimension : 20cm x 20cm x 5cm
Average Resale Price : RM880
http://s.lowyat.net/uploads//attach-90/post-83190-1197858039_thumb.jpg
12.REVENGE DIGITAL 1200watts 2 CH Mosfet Car Amplifier RM290
2 x 500 watts max. output power (4Ohm)
2 x 600 watts max. output power (2Ohm)
2 ~ 8 Ohm load impedance capability
Input gain control
50 - 500Hz variable low pass filter
Low-pass / Hi-pass selectable crossover
Thermal Protection
Short Circuit Protection
Platinum RCA & Terminal Connector
http://s.lowyat.net/uploads//attach-90/post-83190-1201911948_thumb.jpg
13.Vibe Sound VB-352 2 Channel 1600W Mosfet Amplifier RM280
New Vibe Sound VB-352 2 Channel 1600W Mosfet Amplifier
2 Ohm Stable Stereo
Variable Low Pass: 50Hz-500Hz
High Pass: 50Hz-500Hz
Frequency Response: 10Hz to 30KHz +/- 3dB
S/N Ratio: 98dB
T.H.D.: 0.02%
Full Selectable Crossover HPF/FLAT/LPF
4 Gauges Power/Ground Connections
Compact Size: 20cm (Length) 21.5cm (Height) 5cm (Depth)
1 Year Warranty
Superb Quality @ Price Fraction
http://s.lowyat.net/uploads//attach-90/post-83190-1222075375_thumb.jpg
14.Kenko Japan KK-999 2000watts 2 Ch MOSFET Amplifier RM320
NEW Kenko Japan KK-999 2000watts 2 Ch MOSFET Amplifier
2 Channel Power Amplifier
2 x 1000W Output
2 & 4 Ohm Stable in Stereo Mode
Bass & Treble Boost
MOSFET Power Supply
Crossover Switch
Hpass & Lpass Control
Low Level Input
Input Level (GAIN) Control
Thermal Protection
Remote Turn-on/Turn-off Circuit
Protection Condition LED Indicator
Power on LED Indicator
1 Year Warranty
Superb Quality @ Price Fraction!
Weight: 4kg
http://s.lowyat.net/uploads//attach-90/post-83190-1222075450_thumb.jpg
15.Kenko Japan KK-1000 4000watts 4 Ch MOSFET Amplifier RM390
New Kenko Japan KK-1000 4000watts 4 Ch MOSFET Amplifier
4 Channel Power Amplifier
4 x 1000W Output
Bass & Treble Boost
MOSFET Power Supply
Crossover Switch
Low Level Input
Thermal Protection
1 Year Warranty
Weight: 6kg
http://s.lowyat.net/uploads//attach-90/post-83190-1222075433_thumb.jpg
16. HEIDEN 4 CHANNEL BRIDGEABLE 1800WATT AMPLIFIER RM520
(BRAND NEW + 1 YEAR WARRANTY + SATISFACTION GUARANTEED OR MONEY RETURN!!)
2 OHM STABLE AMPLIFIER FOR AB CLASS AMPLIFIER
1 OHM STABLE AMPLIFIER FOR CLASS D AMPLIFIER
MOS-FET STABLE POWER SUPPLY
GOLD PLATED RCA INPUT JACK
GOLD PLATED POWER & SPEAKER TERMINAL
THERMAL & SHORT PROTECTION
POWER OUTPUT: AT 4ohm 75W X 4
POWER OUTPUT: AT 2omh 140W X 2
BRIDGE POWER: 250W X 2
ADJUSTABLE INPUT SENSITIVITY: 150Mv-5v
VARIABLE HPF/LPF FREQUENCY: 50 – 250Hz
POWERFUL BASS BOOST: 18dB at 45Hz
FREQUENCY RESPONSE AT +/- 1Db: 10 – 30KHz
T.H.D. : 0.05%
SIGNAL/NOISE RATIO: 90dB
SEPARATION: 60dB
INPUT IMPEDANCE: 10K ohm
http://s.lowyat.net/uploads//attach-90/post-83190-1222075534_thumb.jpg
17.AMERICAN PRO VS-3502 400W RMS 2 Channel Amplifier with Bass Control RM390
*Flashing & Dancing Lights Following The Rhythm Of Music*
Bridgeable 2 Channel
2 Ohm Stable
800W Max Power
In Built Crossover
Wired Bass Remote Control With 20ft Wire
Variable LPF (30HZ-500Hz)
Variable HPF (50Hz-1KHz)
Variable Bass Boost (0-18db)
Selectable Bass Frequency (30HZ, 80Hz & 120Hz)
Mosfet DC-DC Converter
RCA Line Output
High & Low Level Input
Tri-Mode Speaker Connection
Two Way Protection
Remote On/Off By 12V
Soft Delayed Turn On
Dancing Rhythm at the Rhythm of Music
LED Power & Protection Indicators
Gold Plated RCA & Terminal Connectors
1 Year Warranty
Chrome Finish
Weight: 6kg
Product of the U.S.A
http://s.lowyat.net/uploads//attach-90/post-83190-1222075671_thumb.jpg
Please call 0129584333 or email [email protected] for more details and best price.
Kindly take some time to verify my credibility via my TRADELIST below.
http://forum.lowyat.net/topic/19575/+2899
