integra Headcounts!!
My friend sold his DC2 4 door n has a set 4pc door panel DC2 typeR forsale n some loose parts, pm if inetersted.
sorry bro, those went with the car. only have 4 doors with side mirror, rear boot with rear lights but no rear spoiler, rear bumper, n 4 door panel.
4 doors ?? as wat i know, if 4 doors, its ald a DB wor...door panel ? wat door panel is that ? type R got 4 doors ge meh ? i really dunno that ...
yes typeR got 4door cause the ori. sticker is still on the two rear door n for ur information, typeR 4 door is DB8.
guys let's fix a time....
Wat say 3 or 4 pm?
Yes Dataran Prima is near Baywatch
Kent wat is the name of the mamak?
3pm is ok. Am thinking whether to join you guys or not cos later that evening got wedding dinner to attend in Cheras. Really want to join la. If earlier then better lo. At least got time to get back and change.
JINEIL2EN this Sunday....on or not
Gandalf you come prepared then straight go for your wedding lor
take a look at this DB8 type R
http://i2.photobucket.com/albums/y20/monsterEG/DC2-TypeR-4ii.jpg
http://i2.photobucket.com/albums/y20/monsterEG/DC2-TypeR-4i.jpg
SPECIFICATIONS
3-door Type R
4-door Type R
Model Type GF-DC2 (3-door Type R), GF-DB8 (4-door Type R)
Transmission 5MT
Layout FF
Seating Capacity 4 (3-door Type R), 5 (4-door Type R)
Dimensions & Weight :
Length / Width / Height (mm) 4380/1695/1330 (3-door Type R), 4525/1695/1365 (4-door Type R)
Wheelbase (mm) 2570 (3-door Type R), 2620 (4-door Type R)
Tread Front/Rear (mm) 1480/1485
Indoor size Length/Width/Height (mm) 1650/1385/1090 (3-door Type R), 1830/1380/1120 (4-door Type R)
Weight (Kg) 1120 (3-door Type R), 1160 (4-door Type R)
Minimum Ground Clearance (mm) 135
Engine :
Engine type B18C
Engine Watercooled IL4 DOHC VTEC
Displacement (cc) 1797
Bore x Stroke (mm) 81.0 x 87.2
Compression Ratio 11.1
Fuel System PGM-FI
Horsepower (PS/rpm) 200/8000
Torque (Kgm/rpm) 19.0/7500
Drive Train :
Gear Ratio 5MT
1st 3.230
2nd 2.105
3rd 1.458
4th 1.034
5th 0.787
Reverse 3.000
Final Gear Ratio 4.785
Suspension Front/Rear Double Wishbone / Double Wishbone
Brake Front/Rear Ventilated Discs / Discs
Tire Front 215 /45ZR16
Tire Rear 215 /45ZR16
Fuel Capacity (liter) 50.0
ok...the mamak's name is Restoran Nasi Kandar Sedap, with Yellow board...
wa...if 3pm,very hot ge wor....our tegs cant tahan the hot weather ler....lol ^^
Anyone interested in my rims - DC2 98Spec 16" rims 114.3X5? It's up for sale!
Please go here:- http://www.zerotohundred.com/newforums/showthread.php?p=1389775
