little intro about Hyundai Accent,
Source:
Kah Bintang
Advanced Transmission System
GRADE LOGIC and FUZZY LOGIC prevents up-shift while driving uphill to obtain torque necessary for a silky smooth ride with optimum power delivery. Shift pattern is varied according to slope condition.
Accent's advanced alpha transmission features "Skip Shift" control. To reach the correct gear which may be more than 1 gear away, it can bypass 1 gear altogether through skipping - which reduces shifting time.
The automatic transmission even takes into account altitude and air temperature readings to determine its ideal shift.
Suspension
With the MacPherson strut configuration for front and dual link for the rear with Anti-Roll Bars, it provides a smooth, stable ride with excellent road handling characteristics.
What's more, the Accent's suspension are gas filled instead of the more traditional oil dampers for improved comfort and handling.
So Much Quieter
http://www.kahbintang.com/Images/LC_NVH_Large.jpg
Accent has been sound-proofed to
ensure a quiter, more relaxing
ride all round targeting at major
areas of noise intrusion
and vibration sources
Multi-function LCD Computer Display
Clear instrumentation as well as LCD display which even indicates to you the average fuel consumption for the last 100km, expected distance to empty tank and ambient temperature is one of the many driver friendly features.
http://www.kahbintang.com/Images/LC_meterlarge.jpg http://www.kahbintang.com/Images/LC_LCD.gif
More Accent for you
http://www.kahbintang.com/Images/LC_Heated_side_wing.jpg http://www.kahbintang.com/Images/LC_electric_wingmirror.jpg
The side wing mirror is electrically heated - useful for those days when your side mirror fogs up. The wing mirror angles are electrically adjustable. For that slight touch of class, the inside door handle is chrome coated
Advanced Safety Features
http://www.kahbintang.com/Images/LC_body.jpg
By virtue of the
Accent being marketed as a world car in all major international markets, it is also certified under their safety regulations such as the FMVSS in USA, tested to NHTSA standards and in Australia and Europe under their equivalent rules. The Accent meets or exceeds US and European crash safety standards.
The Accent's steel body is built around the Safety Cell Concept where optimised steel body is designed to absorb and channel energy away from the occupants. Side Impact Bars incorporated inside the door absorb impact from the side
An integrated built-in dual proportional control valve PCV Brake System at the master-cylinder distribute braking pressure between the front and rear wheel so that safer straight line stop can be made
Testing done by NHTSA based on USA 2003 Hyundai Accent (Latest Release) 4-DR. Maximum score possible: 5 stars
NHTSA
http://www.kahbintang.com/Images/LC_side_crash.jpg http://www.kahbintang.com/Images/LC_frontal_crash.jpg
Frontal Star Rating
Driver ****
Passenger ****
Side Star Rating
Front *****
Side ****
Rollover Resistance
Overall ****
is it enough to compare with Proton?
How often Proton send their car for crash test?
I can only recall they send WAJA for EURO NCAP, and WAJA only score 3 star (which is the lowest ) overall in its class.
Correct me if I'm wrong.
