how to clean injectors ourself??
edwin_lcw said:
i don`t get u bong ? tell in detail .......
what i mean is for NA, i can simply disconect thr air filter from tt and spary the tt cleaner rite.
then how about turbo car.
the tt is conected to turbine rite.if i disconnect it the hose from intercooler and rev it
will it be harmful to the engine????
yes....for NA u can do tat, which u still can start yr engine even without air filter connected.....
but for turbo car, u can't start the engine when the air filter hose is removed from the TB.....cuz there's no more vacuum after the hose remove.....actualli can start la, but after tat engine die lo
hi guys,
am newbie and was reading this thread. yesterday i got myself a carb/throttle body cleeaner spray. i disconnected the airfilter hose from TB on my gf's Putra and spray whilst revving. no problem.
then i tried on my stock 1.6 (only using open pod and gull set gti extractor-exhaust) when i remove the airfilter hose from TB the engine dies. can start the engine then after a while dies. tried starting then pressing accelerator even worse dies straight away as soon as press accell.
tried to adjust the timing screw on TB then something funny happened. the screw like soft and just gave way. so i cant turn it anymore. please tell me why the engine dies and also why the TB timing screw give this problem.
wanted to improve by cleaning, but things are worse now as cant adjust timing and cant rev without air cleaner hose attached.
hope you seniours can help me...
thanks
regards
khalil :confused_smile:
i've explained in the msg above.....onli stock car wif stock air filter hose onli can start engine when the hose is removed.....
if using open pod filter u can't start the engine....it will die
wat i did it..remove the rampipe...clean the butterly at TB (spray it).......then conected it back n start....
after that..remove one of the vacuum hose n spray thru it into TB while revving at 3000rpm....
or u can spray all the vacum hose to the tb....then after all DONE..then only start....hv to accelerate n start......then u can notice white smoke from ekzos....
my 2 cent.....
*english not good..pai seh:_:
my 2 cent.....
bro, can show the pic of vacuum hose???? pic of putra engine prefered......
thanx ya
chronic_ska said:
hi guys,
thanks
regards
so now ur car only can be started if the air-filter hose is attached????
don really understand ur statement "the screw like soft and just gave way" ??
if the skrew came out alr, cant u just skrew it in back???
1. can be started without air filter hose attached but dies soon after. especially if i press the accellerator the engine dies.
2. the screw disintegrates
3. since no more thread to screw i cant turn it at all. it is still there but cant be turned with screwdriver as no thread left.
nofear, for ur putra engine. like wat i do to mine, u know the vacuum hose connected from ur fuel regulator to ur intake manifold? u can unplug the hose from the fuel regulator side, and let it suck in the cleaner to ur inatke manifold from there. or u can use the vacuum hose on top of ur TB got 3 hose there, i forgot which one to use edi.
thanks for your help but the putra no problem. my satria engine dies after remove the airfilter hose. and no point to use ur suggestion as my cleaner is more for cleaning the TB. just wondering if anybody can explain why the engine dies and how come the timing screw just disintegrated. cant adjust my timing now. thinking of taking the whole thing apart and attempt to get the timing screw from my old TB and replace it on the current problematic one. hehehe..
thanx.............
but take out vacuum hose so the fuel from fuel regulator will spray here n there or not?????
if just spray from the throttle body also same right????? but i believe it's not as throughoutly as u did........
thanx bro
dude...no worries, the vacuum hose from the fuel regulator wont spray petrol out. coz its vacuum, no petrol is suppose to be there. if got petrol spray out means ur fuel regulator got problem edi :) just cabut with confidence, u will see ur engine idling like go up abit, coz when u cabut the vacuum hose, it actually simulates full throttle.
if for turbo car will dies out after removing the hose, then ho i going to spray the TB cleaner>??????:Not_Impressed: :Not_Impressed: :Not_Impressed: :Not_Impressed: :Not_Impressed:
i'm sure there is some way to do....which need 2 do something 1st b4 removing the hose so tat engine will still running ter the hose is removed.....if wan clean TB, better take out the TB n wash it then put it back
i really don feel like taking out the vacuum hose.........
so spray thru the throttle body to the manifold also the same right???
or try 2 use a straw lor...........
Hi, i need help from all sifu here. Is there anyone can shows me the pictures of exact parts of TB need to spray the cleaner?? I am noob in engine parts.
haha better teach u pritically ...... driving what car n your location ..... ? i feel like yam cha ......
Write your reply...
