HKS / VP / Lucas Octane Booster & engine cleaner
-High concentration hyper polyether amine (PEA) deposit remover
- Deposit in combustion chamber and spark plug due to tuning or long period operation will be easily removed.
- It is an additive for gasoline to recover performance of engine.
- By high concentration hyper polyether amine (PEA), cleaning performance is much better than ordinary items. (Main ingredients of ordinary items are about 10 - 40%. DDR is 75%)
- Resolving performance at lower temperature and solubility to oil of hyper polyether amine is much better than old type PEA and this prevents deposit and sludge.
- A bottle (225ml) per 75 Liters of gasoline. As it is In-tank type, it is easy to use.
- It does not damage any fuel parts like injector or any other metals or rubber.
- It is applicable for any gasoline engines including normal port injection, direct injection, carburetor and rotary engine.
- Available petrol and diesel type
Made in JAPAN
HKS Deposit Remover (Pertrol) : rm95
HKS Deposit Remover (Diesel) : rm85
HKS HIGH OCTANE BOOSTER (INCREASE ABOUT 5HP) HKS DHOB is a fuel modifier. DHOB improves the property of petrol, making it burn in a more controlled manner - more evenly and more complete. It also has the side effect of improving the octane rating of the petrol. HKS DHOB gives a better throttle response. The metal can makes it safe and easy to transport and running too rich a mixture was not harmful to the engine in anyway. A recommended mixture ratio of 500ml to 50litres, this means for a full tank.
Made in JAPAN
VP RACING C5 octane booster is perfect for hi-compression normally aspirated engines,as well as supercharged, turbocharged and nitrous-assisted engines that require the chemical properties of a race fuel to achieve maximum power and reliability.
VP RACING C5 octane booster uses the only truly effective octane improver-mmt- to provide the greatest octane increase available despite the absurd claims of some competitive products - formulated by (VP racing fuels) world leader in race fuel technology since 1975.
-increases horsepower and speed
-controls engine knock,pinging,overheating & run-on
-cleans fuel system,prevents corrosion & improves fuel economy
-approved for use in motor sports competition by most major sanctioning bodies
-net wt:0.946 liters
HKS Octane Booster : rm150
VP Octane Booster : rm180
Lucas Octane booster : rm50
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance @ No.7, Jln PJS 11/24, Bandar Sunway (1st Floor, on top of F3 Racing) or Send by Postlaju.
Operating Hours : Monday to Saturday ( 11am - 7pm )
CLICK HERE to check out my other sales Item !!
Made in JAPAN
Made in JAPAN
