Help
mint8962
Hi, i'm driving a G100 standard engine. My engine middle plug not function due to d lubricant blow up and this make the plug wet. The garage guy said will cost few hundred to repair or even more and only after checking..
My question now is
1.)The cost to repair this problem really this high?
2.)Beside convert engine, any other better way? Because cash in hand not enough.
Thx for all the experience share by u all.
If i catch your story right, your problem is ..... your gasket blow, hence the engine oil flow up to the spark plug (head area) and now you need to do top overhaul.
Typically what the guy needs to do is to open up the head, change the gasket, clean up all the mess by the engine oil including the head + spark plug and then put back everything. It's not much thing needed to change but the labour is where all the money goes.
So if the question is whether it cost so much to repair... I would say around there. But you didn't specify how much ? 100 and 900 is still few hundred. :_:
Added : Oh yeah, forgot to answer your question, if you want cheaper, DIY is the way to go !
Thx tibun for all d opinion, especially d added part. Hahaha.. Joking...
Yes, i think wat u said is almost d real... Mmmm... Must do overhaul ar... but some ppl said after overhaul d engine not tat good already wor..
Abt d price.. As u know normally how much thay will charge? Coz they said need to open up d top n check then only can give me quotation and honestly my cash is stuck plus i worry being "cut".. Kekeke...
