help needed.......18 t sifusss
@lvin
Subang
anybody knows what is the diffrence between ecu coding of 7377 and 5663..im currently using and 5663 and have change it to 7377 coz they say its better coz 7377 have more hp..
problem is....now that i have change it to 7377 my turbo indicator on the meter panel dosent work..anybody got andy idea.....
Didn't know there is code for the ecu. Where did you went to change the code number? They should have some idea even before start changing it
:smile:
7377
hi frens,
i m just planted 4g93 came with 7377 ecu into my wira
Also having a same problem. turbo indicator doesnt work. my frens car with 5663 ecu turbo indicator is working.
i m now currently also facing another big problem, i sent my for for dyno test, when car standstill fuel is enough, when full trottle fuel is not enough at all. anyone here can advice, to change fuel pump or to install fuel regulator????
did u change the fuel tank or use back ur wira tank? ur wira original how many cc.
maybe the fuel pump on the stock wira tank have a low rate (l/ph)... try to change it.
theres a lot of possibility of running lean..
some are not enough fuel supply due to fuel pump failure, fuel line clogged or maybe injectors clogged.
try to put injectors cleaner additive or get them blueprinted if ure sure ur fuel pump is ok.
before investing on a fuel pressure regulator, try check the fuel pressure 1st by getting a fp meter, around rm50 sumthing. ur stock regulator (4g93t) should supply enough fuel unless the fuel pump is broken. (35-38psi idle, 38-45 psi throttled)
theres many other possibility also, regarding engine internal but this case have to be elaborated in more details. ;p
wah rojak wan. y dont u check with the wshop u did the conversion.
what dya mean na throttle body... 4g93?
by the way, how much ure boosting during dyno?
yup... na car trottle body is bigger than turbo 1,
yno @ n1 sunway, 0.9 bar @ 209hp @ gear 1 already shortage fuel supply.
n1 mech dare not go further.
hey... anyone here is selling evo stock ecu or anyone wanna buy stock gsr ecu ???
Write your reply...
