Headlamp Got Water Inside, Help! Help!
kacyp
60
uk.geocities.com
anyone pls help me, how to get rid the water inside my headlamp and anyone knows what is the cause of this phenomenant.? :ph34r: :blink: :ph34r:
headache
1,651
Malaysia
What car and how old is it?
kacyp
60
uk.geocities.com
my car is accord sa6y, 20 years old oledy, but the head lamp recently change.pls help :ph34r: :blink: :ph34r:
headache
1,651
Malaysia
Go back to the mechanic who install for you. Ask him to put sealant.
If not, can DIY. Just buy some Silicon Rubber (same as those used to seal the fish aquarium). You have to remove the lamp first and with careful observation, you'll know where to apply the sealant.
To dry the water, use a hair dryer. :)
kacyp
60
uk.geocities.com
thanks for the advice, i will try it.... :ph34r: :blink: :angry: :o :D
Engine Oil Leak Classified as 2 Section
Leaking , Or Comsume into Piston .
Leaking
1. Firstly to check is whether there's Engine oil Stain at Bottom of engine (aka Oil Sump) , place where engine oil keep inside . If it's Terribly Wet , means there's Serious Leak. Or you can Put a Newspaper / cardboard at bottom of your car . But this Not applicable for Small Leak , hard to be seen.
2. Next is to Check Which part Have the leaking . Classified to 2 parts . Upper part...
