- Joined
- Jul 3, 2006
- Messages
- 376
- Points
- 1,516
the spec of the amplifier..
1. Average Power Output/CH into 4 Ohms, 4 Channels Driven @10Hz~40kHz, 0.5% THD 85W X 4 or 170W X 2Ch @1kHz, 10% THD 250W X 4Ch or 500W X 2Ch (Total Harmonic Distortion (THD) Amount of change in harmonic content of the signal as it is amplified. A lower figure indicates less change and a more accurate amp. THD below 1% is inaudible.)
2. Low Pass Filter (VARIABLE) 40Hz ~ 150kHz
3. High Pass Filter (VARIABLE) 80Hz ~ 1.2kHz
4. Output of Bridged (BTL) Operation into 4 Ohms @ 1kHz, 1% THD 1000Watts
5. Frequency Response (-1dB) 10Hz ~ 40kHz
6. Signal to Noise Ratio ("A" WTD) >100dB
7. Input Sensitivity 100mV ~3V
8. Input Impedance 22k Ohms
9. Operation Voltage (Negative Ground) DC 12V
10. Speaker Impedance @ Stereo Driven 4 Ohms
11. Fuse Rating 40A X 1
12. Dimension (WxHxD)mm 260X58X320 Weight 3.2KG
please give me any comment about this amplifier..i want to use the amplifier to support my componen speaker from soundstream
