2 all sifus out there..whut is the max boost that stok gtti can reach without installing the fcd or changing the ecu mapping but only use the tulang ikan? mine can go only 0.8 bar> ..is that the best reading with the spect given? :Not_Impressed:
ali said:Hi..
should be able to boost up to 1 bar, as per Mr Otomen. or else something is wrong with your tulang ikan, maybe get a bigger tulang...
tq
ali said:hmm...maybe somebody else can help you.
I am confused already, since i've been using FCD for quite a while and forgot how my car was back then...
another thing is, all the while i thought fuel cut or the boost cut is a same thing ( at least for our CB70, it will have the same result.. ) but maybe i am wrong.
Just fix a fcd...problem solved, hopefully.
tq
Maxx said:u didnt have fcd thats why got fuel/boost cut.
u must remove the cut first b4 increasing boost.
but beware using fcd will lean out ur AF ratio.
stock GTti will have cut if above 0.9bar.
std boost around 0.8~0.9bar
stone_GTti said:hi ppl, is easy modified ecu mapping of charade GTti?
and you now what is the code/ref of the ecu? thks ;)
amadbing said:use fcd the max boost is 1 bar only?
ali said:Nope, it will go up till it start to leak or blow. Maybe around 1.8 with piggy back+standard internal.
you try first, then tell us..:regular_smile:
tq
