noob here... can anyone advise or maybe suggest a mechanic to do an overhaul for svt?
pls tell me how much roughly... much appreciated, thanks!!!
eerr..overhaul only? no balance ka? hehehe![]()
hhaha ...balance engine expensive mah ....no budget ....
but do port polish is cheaper la ......hehe ...
got 1 more question ......do anyone do re-do the shim ....so tat the engine more silence .....i heard re-shim cost abt RM 20-30 per shim ......
= RM 20 x 20V = RM 400 edi lo ....LOLz. .....damn ....y no 16V ....LOLz ....haha
but i think 4AGE-20V engine all got big tek-pet sound la .......hehe
is it true some toyota fellas use B8T pistons also ??
nvr heard bout it b4, usually HONDA fellas use it s d cost is cheaper.........
anyone try 81.5mm piston before? how big is the performance increment just for the oversize piston alone?
Need some advice for you all sifu out there.
I'm planning to overhaul my 20V BT Manual.
At first, I tot only do the following.
1.) Port & Polish
2.) Re-shim
3.) Full balance
4.) Oversize piston using ori 81.5mm
5.) Change conrod & main bearing ori
6.) I don't to change Metal gasket cause i'm already using TRD 0.8 now
If i'm not mistaken this will cost me somewhere about 3-4K.
Second Option will be
1.) Port & Polish
2.) Re-shim
3.) Full balance
4.) Toda 82mm Oversize forged piston
5.) Change racing conrod & main bearing
6.) Use back the old TRD 0.8mm gasket
Assuming that the second option cost me 6-7k, which option will you guys prefer and do you think it is worth the money to invest.
I'm using my ride for daily usage and sometime itchy, tekan a bit.. especially when i was travelling outstation.
Pls. advice.
TODA and other aftermarket performance part do state "for racing purpose use only" normally do have a lifespan on the usage......
My opinion for guys driving 20V now.....go for 7A.....better torgue and save more fuel....my 7A gave me extra 70km km compare to my 4A.....
Power speed charging around RM3K+ to convert it to 7A for you, includes labour + parts + 7A block.....i paid more for it coz i balanced it and rebore to fit 81.5mm piston additional around 1K+.......value for $$$ upgrade compare to cams n others
1.) Port & Polish
2.) Re-shim
3.) Full balance
1.) Port & Polish
2.) Re-shim
3.) Full balance
Pls. advice.
