- Joined
- Apr 22, 2005
- Messages
- 1,141
- Points
- 5,138
Fuel = any mentioned above
Engine Oil = any mineral, 20W50
-recommend castrol
FC3S and the 13B engine is old-school by now. Little real benefit with synthetics but if your budget allows, go ahead. Not recommended to switch from mineral to syn and then back to mineral.
Wack in Mineral only.. no need any fancy mumbo jumbo synethetic.. ron95 also BOLEH!
savahn, What sort of fuel do u recommend? U driving a fc3s too? My friend's FC is turbocharged but he have to be careful during launches on 2nd gear, coz the wheels (15s) will go spinning out of control fishtailing the car. I think the previous owner did some mods on the engine.sb3,
the 1985-88 FC3S maxes out between 145 (stock NA) and 190HP (stock turbocharged). That's not much in today's world.
It can run on RON92 - from Caltex, but starting the engine up is kinda crap. It will crank for a bit before actually starting. I've stopped buying Caltex as I had difficulty starting up even with their Ron95.
Engine explode or not - 1 bar, hehehe.. small little snail only, maybe ask him to go for bridgeport.wack only... 1 bar
His boost pressure (@ dash meter) is not working. Any idea how to set up those huge boost meter on the A pillar or on top on the dash? which wire to connect?It is up to every owner to try out what works for them.
Just remember to check the boost pressure. Unless you know what's gone into the engine, it is recommended to maintain stock pressure at 0.5 bar.
