yupz.. to win races u need lots of torque..actually i tested sifu Qiw car last time.....hahaha.....on highway they r much better than 4A....bigger cc higher torque.....its all about torque.....
high hp ratings are for hiways..
yupz.. it's free rolling.. only to the front or back..LOL! Hahahaha... Nice one...
---------- Post added at 03:28 PM ---------- 6 hour anti-bump limit - Previous post was at 03:26 PM ----------
d7zul,
O don't FF can drag the rear la... The rear is free rolling, thus it will follow. Unless one deliberately lock up the rear... Then that is different story . Because FF is safety biased.
Put some bricks in the boot mar...
Seriously, I don't think the AE101 body weight is that much different from the ST150 Corona's. Like I said before, the alleged front heavy issue, to me, it's a matter of suspension setting. If you're still using the same spring rate as the lighter 4AGE, then it will not be able to support the additional weight properly causing the understeer & lightness feeling in the rear symptom.
If any of you are still having a Beams in the AE101 body & complaining of the understeer problem, I recommend that you review your suspension setup; especially the spring rate.
I'm just sharing my daily experience of living with my Beams & my BT.
Hi Hifonic,Sir kindly suggest advice a good spring rate or suspension for ae101 w beams redtop manual w lsd?
I felt heavier understeer because m using H&R Lowering spring with KYB ULTRA SR
always bottom in uneven road and pass to hump.
Give me a good set upp for suspension
ha..ha..ha its true..Sifoo Alan has spoken...
I've driven a stock 3SGTE on stock AE111...
driving pleasure wasn't so nice compared to stock AE110 with stock 20V...
although the power is more then enough for me...still, not so nice...the car back end felt so light...
I don't about you guys...
but still power is nothing without "kontol" ehhhh...control...hahahahaha
