EVO 3 Chasis and handling
Bro, will my satria's U-turn take bigger space if i use EVO 3 Front lower arm + ARB? thx
No problem la... U achieve better caster angle. 10-15mm longer wheelbase won;t make much difference. But improves alot in the handling + steering response + damping reponse due to the direct ARB mount onto the absorbers.
U can test my car U turn...
how much just for front pair rotor/disc only? 016-3030322
evo 3 lower arm,upper arm,steering rack,cross member. berapa best price boleh bagi?
kalau masuk satria1.6 tukar lower arm,upper arm,cross member evo3 tapi steering rack nak pakai standart 1.6 boleh ke?
maksudnya nak tukar lower arm and upper arm sahaja.
Bang, EVO 3 mane ade upper arm..? McPherson suspension system bang... Ade lower arm je...
Xyah pakai cross member, gearbox 2WD xleh pakai bang.... kena pkai blk stendet nye...
U've got PMed
Wira/satria/putra/arena ownerz... Improve ur chasis n handling lor.... Wait what summo oh!!!???
bro i have a gti... and i wan to improve the handling... i wan the front lower arm wat the diff wit telinga or no!!!! sorry still new in the part!!!! the cross member and center just plug and play!!! i m using standard gearbox and also adjustable need to mod anything to used this item... plus do u know where can i fix the item... thanks bro!
bro, im interested in the evo3 lower arms and antiroll bar. but i need a crossmember too. im driving 1997 proton satria w auto gearbox. can you source a 2wd crossmember ?
New Posts
