Engine Start Button - Start your engine with style.
does the ignition key become redundant or i have a choice of using this and my key?
sky_legend,
it depends on the wiring methods. however it is not recommended to do that on a street car as security is the main issue.
BlackSamurai,
I suppose so. It won't work on a high tech alarm system too. I think it's all on how it is wired.
Seraph,
The ignition key is not made redundant if you just tap the wire instead of cutting it off.
Seraph,
The button got nothing to do with the 'CHECK ENGINE' light before crank.
The button functions as if you turn your key to START/CRANK. You will still need your car keys to turn to ON position and later you can choose either the button or turn the key to start it.
Hi..
What's the diamater of the button's housing? So that we know what size of a hole to drill?
Thanks
Bob
http://www.zerotohundred.com/newforums/attachment.php?attachmentid=71222&d=1145933646
bro,,how to pull out the button from the wire conection relay part...i mean the button part only...just pull like that or there is the way to do it....
there will be 2 screws at the back of the button. loosen it and twist the button anti-clock wise and you will be able to pull out the button.
hi bro... got the button from you bout 2 weeks bek or so many thanks to you for the prompt respond and fast delivery... and definitely no complains for the price.....just wanna enquire from you... am a bit curious although i dont dare to try.... lets say i start the engine with the button.... and then engine is running.... then suddenly i "ter"- press the button will the it start cranking again or is there a saftey built in the device to not activate the cranking? many thanks
cRuZ1011, Thanks for the feedback.
The push button is exactly like when you turn your key to crank. I advice you not to push the button when the engine is already started. There is no safety device built-in the button as it has no complicated electronics setups. The only way to avoid such accident crank is to place the button far from your itchy hands when you are driving. :P
-bump-
stocks are now limited. please place your orders soonest.
free shipping offer ends on 15th May 2006
Shipping & Handling RM5 Peninsular Malaysia. RM10 Sabah/Sarawak
bump
one of the coolest gadgets you can buy at such low prices.
y got light de ur pic????????????
actually got light or not?>
