I have one Push Start/Engine Start/Starter Switch button like the ones for Honda S200. Colour: red
http://img96.imageshack.us/img96/1202/anglebutton2wo0.th.jpg
What you'll get:
1)Full, step-by-step instructions
2)The Honda S2000 style Engine Start button
3)Heavy duty 40Amp relay so the kit can power up your starter-motor solenoid
4)A professionally produced wiring loom with generous amounts of heavy duty cable
5)Connectors to connect the kit to the vehicle wiring
6)Cable ties to keep the wiring nice and tidy
Can be used for all cars regardless of alarms, immobilisers or locks used. Size 21mm diameter and needs a minimum of 40mm space behind.
No need to cut or solder any wirings, you can DIY under an hour with no additional parts needed. However, you can consider sending it to the shops to do it for you and save you all the hassle. Can also be used in place of the cigarette lighter.
To use:
Insert key as normal, turn two clicks (to trigger electronics) and push engine button. You can still use key as normal to start the car (turn it all the way) if you don't want to use the start button
http://img81.imageshack.us/img81/9919/mainshotyp4.th.jpg
Text atau call 012-279 1857. RM150.
What you'll get:
To use:
