Engine Start Button - Start your engine with style.
ftzone said:
Different vehicles will have different color codes. Bring it to an accessories shop wireman he will know which is which by testing.
Installation methods explained in post #1
** please compile all your questions in a single post.
seems like it's possible to be DIY by the car owner. interesting...
Bro, how to order from u, bank in money arrrr?
sms me ur details, name , acc no and stuff
kiran - 0122083776
got warranty arrr?
Monstaville,
Loc: Seberang Jaya (Penang)
However, this item is not available for COD. Unless you buy in quantity. No time to meet up.. later I come late you scold me pulak.
Darren2627,
How to give u instruction la.... Only need the IGN +12V Wire and ST +12V Wire. If you know where this 2 wires located in your car, you can fix this engine start button already. Different cars different wire colors ma.... it is impossible for me to know them all...
Darren2627,
The wires are located at the back of the keyhole. There is a socket where you can detach it from the key assembly. You will need some wiring knowledge to hotwire the button. I strongly suggest that you just bring this button to an accessories shop to get it done. I did mine for a mere RM20 installation fee only. Don't need worry I will spoil my wiring. When you buy this button from me, I will include a diagram where the wires are to be connected.
hi bro me wanna get one... can u pls pm me the procedures - your bank a/c etc etc me live in Petaling Jaya... many thanks.... also got warranty ah how if i so lucky get one, install already push but cannot start ah?? thanks a bunch...
how much to charge about the transport fee??im location in jb.
as i understand,just to use 2 wire to connect to the button:
1. Ignition (ON) 12V power Wire
2. Start (ST) 12V power Wire
but the Ignition (ON) 12V power Wire need to cut off to connect the ignition key??
Darren2627,
Refer to the attached picture for the dimensions.
There is no need to cut the IGN +12V wire off the key assembly, you just tap it.
The way you are asking me these questions, I strongly suggest you just bring this button to an accessories shop to get it done. Without wiring knowledge and the correct tools to slice wires, the job would be rather difficult. Furthermore, you may need to drill a hole in your 'desired' panel to get the button go through as in my first post picture. If you have further questions, kindly call me at 016.4539687 It will be better for me to explain verbally as I am poor in explaining via text.
The new one has got additional 2 switches installed. that's what i can see. my question is: do those 2 switches illimate the use of key to start engine (totally using those switches)?
New Posts
