Engine OIL Top UP?
Erix7
hi,
i keep thinking of this question, let say if the engine oil getting low/ dry up to half o more than half,..but ur mileage is being use like 1.5k km only..
is it ok to top up the engine oil o anything??
any1 get wat i mean?? o terus go service change the oil filter n engine oil again???
infoz plzz thanx
1.5 K KM ?
as in... 1500 KM ?
something is seriously gone wrong with your engine... mine i run 3000 over KM.. only done down like 1 CM.
check ur oil pan gasket. OMP for any defect. once u run DRY on ur rotor, good luck.. go get another one from Glen.
Yes, you can just top up engine oil to the appropriate levels, but make sure u use the same oil, if not, same ratings. i think u got a leak some where, check ur pan or oil filter pedestal for leaks. other weak points will be oil coolant lines.
