emanage tuning and installation
Hi,
i did some survey on emanage. I stil have some doubt on it.
Can Emanage support Wira 1.5MMC ECU?
if can, can it tweak on the "ignition"?
thanks .....
bro vteckiller, thanks for the tuning and dyno hehehe
next time mau add NOS i cari u lagi hahahaha
let me think and cari $ dulu hahaha:driver::driver:
your most welcome bro..
no probs..thanks for lunch :)
NOS soon ...hahahaha
guys,
those who wana add and tune e-manage for turbo car, do contact me. I can arrange for dyno tune as well. Just a e-manage even with ignition harness not enuf to tune turbo car, need to add something to advice the e-manage to control the car follow your boost where standard e-manage can't do that.This will give you more fine tuning and more hp.....
For more details, pm me.
Hi,
thanks .....
yes emanage can be installed in 1.5mmc ecu..
confirm can no probs at all..
for sure thing!
well,to all sorry have not been onlne for some time now..
been really busy..
sorry.will try my best to reply within short period of time..
cheers..:driver:
Joshua,Thank you for the tuning. Didnt know wht to expect but after a search on the net, I found out tht my current hp (nothing to shout about) is already higher than those with stock engine (like mine) but on 2wd. Next thing is to sort out the boost controller setting. You should find out more about this controller la.....I believe more and more driver will be using it......
bro vteckiller,
have u done e-manage on stock vios?
how much hp increase can be expected? thanx..:biggrin:
btw, whats the different between e-manage blue and ultimate?
will it help abit if install muffler + filter + fuel pump combo?
can achieve around 10 hp...?
if u wan tune on dyno, u better MOD more depends on your budget, but NA car, hard to get more hp , because we hard to get more air, even just change a filter is nth much, and i think no need change fuelpump.. because u just change airfilter or exhaust system.. if u install muffler is nth change much, unless original those muffler or catalyst u cut out .. with piggyback tuning, i think 10hp wheel, maximum can get.. u should change highflow airfilter, example k&n, HKS, or other brand, dun use those cheap cheap rm20 filter, it worst and bad to your engine... if u want DROP in, there are HKS and K&N which fit your original filterbox, if you wan more power, i think u can change open pod, but it cost a bit more on modify it..
i think better u need to ask your mechanic/tuner.. if u got budget.. go for NOS :biggrin::biggrin::biggrin: easy way to get hp on stock.. and fun too...
me also thinking to pasang on my ride, maybe next month..:biggrin:
bro,
i already bought e-manage together with basic n ignition harness...
how much is the cost for only installation??
the rm300 is it = installation + dyno +tuning fuel n ignition timing???
my car is satria 4g92mivec...
joshua bro,
this Saturday morning u free or not? want to pasang ignition cable and dyno tuning at ur place.
last time dyno tune without ignition timing, the car feel quite heavy and the pinging quite obvious :bawling::bawling:
hi joshua i will come this week to do the e-manage installation and dyno tuning. I have ignition harness, injection harness and cable connect to pc. Give me a best price that all complete done with control mivec open at RPM 5200.
By the way, my car is FTO Mivec V6 2000 should i use injection harness? i try to call you and your office last few day but no body answer.
Hi guys...
I want to know the price for :
i)e manage ultimate
ii)ignition harness (if needed)
iii)installation
iv)dyno tune
v)opinions
My ride is myvi 1.3 manual.
TQ in advance :biggrin:
Write your reply...
