yes.....agreed..........Y not have your radiator clean up FIRST.... put inside clean water such as filtered water or if affordable use RO water n flush out each 4 months or 6 months its depands on U.....n inspect your radiator n condensor fan...make sure both fan working........inspect your water hose make sure no leaking n crack at the hose n the joinning......n last make sure your engine oil is enough n no leaking........Originally posted by khguan@Nov 23 2004, 22:31
ur car already got a neddle showing de temperature of ur engine... so y wanto put another light?
i think not practical.. bcos ur engine will not always overheat... so if u put a light.. will be "chor teng" n will never light up until ur engine overheats.. until now.. i never experience an overheating engine b4..
well.. i suggest dat u put a water temperature meter which give u constant reading would be much better... :)
then don't worry about the temp already.....temp will not going up one......can concentrate on the road...Originally posted by 12oY@Nov 25 2004, 00:09
emmm i also dun know how much my max temp... so any one have any ideal ??emmmm by the way ....when i drive i also seldom notice my temp meter lo... wandering got after market 1 huh??
Originally posted by ksgoh+Nov 25 2004, 12:15 -->
QUOTE (ksgoh @ Nov 25 2004, 12:15 ) --QuoteBegin-12oY
@Nov 25 2004, 00:09
then don't worry about the temp already.....temp will not going up one......can concentrate on the road... [/b][/quote] agree.. always maintain ur water/coolen.. |
