DIY MAF sensor cleaning
littlebeetle
51
508
Recently decided to clean my mum's suzuki swift. I didn't managed to captured the photos due to only I work myself and hand full of dirt
It has not been clean since car delivered couple of years ago.
Step 1: remove negative battery terminal
Step 2: Remove the entire air intake filter box (tools u need just Philip screw driver). But remember the process of the removal as you need to assemble it back
Step 3: remove the wire connector attached to MAF sensor so that you can take out the entire sensor for easy cleaning.
Step 4: There are 2 screw located on top of the MAF sensor. You need a very short "L" shape screwdriver to loose them.
Step 5: Clean the MAF Sensor (like a match shape) with MAF spray (can be purchase from car accessories shop). You may spray 5 - 6 times interval. The spray will self dry instantly. However you may choose to dry it under the sun but not too long else the sensor will damage.
Happy DIY! :biggrin:
DR78
549
54
5,028
subang
Great tips there..Thanks. do you know where can i buy the crc maf cleaner? cant seem to find it.. Thanks
AD_EG
6,328
231
Ipoh
if cant get crc, you can find electrical contact cleaner from any electrical shops/some hardware store as a replacement.
can also try Ace Hardware or brothers accessory or Eneos to find for MAF cleaner
and remeber not to touch the insides with hands or dont attempt to wipe inside also bro. very sensitive. be gentle. :driver:
ace hardware definately got the spray in stock....
but finding them on the shelf of automotive spray quite dizzy :biggrin:
Hi everyone.
Currently im using 195/50/15 tyre size.
But, for the next change im considering for 205/60/15 or 195/60/15.
The question is, can i use that tyre size? any pros and cons?
Reply is appreciated.
