And DIY CAI as well.
that's a very cool CAI holder. Where'd you get this done / bought?
Danz,izso, that's not a cai holder la its an aftermarket air filter, go brothers can see a lot of those.
just cut some of the batang to fit the CAI
Not CAI as open to suck engine hot sir....
Maybe can close all those holes or shift filter to the bumper.....I agree not perfect CAI but atleast there are still a lot of outside air coming thru the hose.
haha not only jpj, all of us will laugh at u :proud:Ha ha ha...I don't dare to do that...I don't want jay pee jay to be my good friend...
Water go in woh! and hard to do polishing.....hahahahahahacan DIY this..
This one block air woh!......Like this one...
yepp sure can use 1, manifold is hotter than block maaahello guys need to know can this spray can also applied to engine block ?
where can i get ?
i want to spray my engine block to flat black any suggestion how to make it ?
I'm already take out all the internal part so need advise what spray can applied for block engine need flat black colour
:hmmmm:
make sure the engine block is free from oil stain, grease or dirt. If not the paint wont stick properly and your spray paint will be a wasted effort.hello guys need to know can this spray can also applied to engine block ?
where can i get ?
:hmmmm:
Most engine degreaser are petroleum base therefore you may need to use soap to wash the degreaser off also and then let dry kao kao firstmake sure the engine block is free from oil stain, grease or dirt. If not the paint wont stick properly and your spray paint will be a wasted effort.
Try engine degreaser. They are tough on heavy oil, grease, etc.
Tq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it backMost engine degreaser are petroleum base therefore you may need to use soap to wash the degreaser off also and then let dry kao kao first
Sent to machine shop, come back should be quite clean, right? If not in the car you can clean with whatever solvents, rather than spray degreaser. Just make sure no dirt and oil before sprayingTq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it back
or u can go to hardware shop & try to find water based degreaser, ace should have lot for oil & grease, its spray leave rinse method.Tq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it back
