DIY - Apexi Turbo Timer Installation
Speeder
366
Dear all DIY specialist,
I just buy a Apexi turbo timer (pen type which can show A/F, O2, Battery & Timer) and would like to DIY installation it to my car (Wira 4G15 SVDO).
Have anyone here can teach me how to install it? Especially A/F wire and O2 wire connect to which wire of car?
Thank you.
zeus83
979
55
KL-Damansara
the shop i go to, bloody wanna charge me RM90!!! then nego till 55...wat a rip off .....
bro speeder,
Don't risk DIY the wire connection, better go to a shop :)
Transformers
5
bro if you to install O2 sensor and A/F for pen type turbo timer...i prefer to you to go to specialist shop because 02 sensor and A/F must take from the ECU.....
Speeder
366
Dear all sifo and adviser,
Can you advise me how to install?
Thanks..........
calvin9683
1,768
171
JB
O2sensor/AF can tap directly at ur stock exhaust sensor....
dat's a easier/lazy way to do it la...
if u got ur ecu wiring diagram, then its not hard to locate the pin....
Speeder
366
really can direct connect to stock exhaust sensor?
That's why I need the ecu wiring diagram.........
Can somebody share with me?
Transformers
5
i also use apexi pen type turbo timer.....but A/F and 02 sensor i don't use it because do know where to take it or tap it...because some of my friend said 02 sensor and A/F cannot do a tap2 like we tap at the timer wiring.......
so i also try to find ECU diagram for perodua viva.....
Speeder
366
If cannot do the tap, so what can do? soldering?
E-Tech
1,115
256
3,183
Johor
Wira 4G15 SVDO with custom turbo kit?
NO? Then need turbo timer?
---------- Post added at 12:32 AM ---------- Previous post was at 12:19 AM ----------
Anyway... here is the link...
blog.autoworld.com.my/index.php/.../ecu-pin-out-assignment
BR
Hi Ninja,
I am currently using Titan on my E34 . Purchased by previous owner .
Two of them I believe it's leaking cause I can see some oil start accumulating .
Making the ride uncomfortable .
Since Titan carried two years warranty , how much does it cost to service it .
Do we need to make an appointment or I just can drop by and expect to get services by Q . ( first come first serve )
Thanks.
