wow.... congrats.... how u tune the AFR??... u got O2 sensor??... or do guessing game??...dwight_my said:Hi SkYwAlKeR,
Thanks alot....I just did DIY tuning of my Carb yesterday.....and this is my observation.
1. If u tighten the AFR screw(clockwise) - it incerases the Fuel
2. If u loose the AFR screw(anti-clockwise) - it decrease the fuel
The screw in front of the AFR is for the AutoChoke (when u start your car in the morning or when the engine is cold)
Note:
the Airfilter will need to be in place during the tuning not too sure WHY....but i guess there is some thing to do with the vacumm system connected to the Airfilter box.
I have also just filled the tank with $60.00 and will observe the FC and update you all... Give me a week.
D
dwight_my said:Hi cookie,
u mention using mikuni carb....where can we get this kind of carb/from which car model? is it PNP (plug n Play)? How much does it cost? and lastly wat are the benefits compared to the std oem proton carb?
Please explain....
D
but u are the master of all sifoo ma....:regular_smile:fstrader said:all also sifooo edi :D
SkYwAlKeR said:but u are the master of all sifoo ma....:regular_smile:
rayracer said:oic!! wah!! so expensive?? got used 1 ah??? what the different between in the 36 and 40?? which 1 good performance and save fuel??? how much need to mod to put back original filter??
Thanks to the guide from Gavan on page 192in this forum, here is what i did.
1.off your engine turn your AFR screw to the tightest you could (turn clockWise)
2.then unscrew it bout 3 full rounds. (turn anti-clockwise)
3.then start your engine and adjust the idling screw (the biggest one on the rightside of the carb for proton)
*** make sure the idling is stable around 900rpm n dun forget to rev the engine a bit each time you do an adjustment ***
4.then you slowly adjust your ARF screw to lean (turn anti-clockwise)...noticing the engine sound each time you turn the screw wether the engine pings(knock) turn it till you notice a drop in RPM(like the engine is choking)
then turn the screw half way out(richen it)/ (turn Clockwise) until u notice the idling of the engine is smooth/stable
5.adjust the idling again to maintain at 900rpm, then you should be fine.
(do tune it after driving a while to suit your needs =)
Note:
if you feel the RPM is hard to climb (eg:it only climbs at early RPM then the engine feels like it doesnt wanna rev) then you should richen the fuel mixture a lil more =)
(turn clockwise)
Well guys i'm also trying it out....no tools /O2 sensor...just by listening and feeling your car's body. may need to do additional adjustments later / after driving awhile.
Will keep u all inform/posted
D
kweng84 said:wow...at last, i have tuned my car to the level i wanted...thanks to Gavan and Dwight for the info of AFR screw...thanks!!
